  • Unique Tactile Pressure-Indicating Sensor Film Helps Capacitor Manufacturer Hold Tighter Product Tolerances
Oct 16, 2007
This histogram from Sensor Products Reveals the Uneven Distribution of Pressure Across the Plates
Pressurex Film Revealed the Uneven Distribution of Pressure Across the Press Plates
Madison, NJ, (USA) � October 16, 2007 � As an innovator of film capacitor technology, SB Electronics designs and manufactures products that are on the cutting edge of today�s demanding electronics applications. To maintain continuous improvement of its manufacturing processes, David Bryan, Manufacturing Engineering Manager for SB Electronics, recently specified Pressurex�, a tactile surface pressure-indicating film from Sensor Products Inc.
Many of SB Electronics� radial lead products are designed to take up the minimum amount of space on printed circuit boards. This is often done by flattening the round capacitor profile in a pressing operation between aluminum plates. A higher than expected yield hit led the quality department to contact engineering to troubleshoot and improve the process.
�After histograms indicated that some of our tighter tolerance parts (�1% capacitance) were going out of spec, and making some initial dimensional measurements, I needed to visually determine the tactile surface pressure,� says Bryan.
Bryan inserted the film which he had ordered in Super Low pressure range of 70--350 PSI (5--25kg/cm2) between the press plates during a product run and saw the uneven distribution of pressure between the capacitors. As a result, he could prove the press plates weren�t flat and were causing uneven pressure distribution.
Bryan continues to use standard tools such as gauges and calipers, but is asking that Pressurex� be included as an on-going ISO quality control protocol. In the past, he had used the film to evaluate bolted flange designs for custom fittings in vacuum systems.
The film has many uses on a multi-layer printed circuit board assembly, including analyzing contact uniformity, verifying flatness (planarity) between semiconductor wafers, and revealing problems such as overloading of connector contacts, standoffs and component solder joints. It is ideal for dozens of industrial applications, such as assessing surface contact inconsistencies in clamps, connectors, heat sinks and heat sealing elements.
Pressurex� is available in seven different ranges that measure pressure from 2 � 43,000 PSI (0.14 � 3,000 kg/cm2) It allows for rapid and easy determination of compression magnitude and distribution. When placed between two contacting or mating surfaces, it instantly and permanently changes different shades of red, with the color change directly proportional to the actual pressure applied. Precise pressure magnitude is easily determined by comparing the resultant color intensity to a color correlation chart (conceptually similar to interpreting Litmus paper).
For a free sample of Pressurex�, contact Sensor Products Inc. at 1.973.884.1755 (USA) or visit their website to request a free sample at http://www.sensorprod.com/sample. Their entire line of products and applications can be viewed online. SB Electronic Inc.�s website is http://www.sbelectronics.com.
About Sensor Products Inc. (USA)
Headquartered in New Jersey and established in 1990, Sensor Products Inc. is a world leader in the manufacture and distribution of tactile pressure sensing solutions. Their customized and off-the-shelf products are installed within all of the Fortune 500 industrial companies as well as thousands of smaller manufacturing firms. Their sensors are used in applications as diverse as tire testing to semiconductor manufacturing and from R&D labs to space missions. Additionally, Sensor Products provides in-house and on-site stress and pressure mapping analysis, as well as a variety of technical seminars.
Feb 19, 2010 -
Use of Pressurex Pressure Indicating Sensor Film Increases Bond Strength and Reduces Defects in Ultrasonic Welding of Electronics
Dec 22, 2009 -
Undetected Pressure Variations in Flip Chip Assembly Reduce Yields and Raise Costs
Aug 09, 2009 -
Pressurex® Film Promotes Uniform Nip Pressure Distribution to Reduce Dry Film Resist PCB Lamination Defects
Nov 06, 2008 -
New Pressurex Zero� Sensor Film Measures and Maps Very Low Contact Pressures
Jul 19, 2024 -
Koh Young to Host SMTA Atlanta Chapter Technical Meeting on State-of-the-Art Test Techniques presented by Vaughan Carlson from VALUE Engrafting
Jul 19, 2024 -
Electronica 2024: Where Vision Meets Reality
Jul 18, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Unique Tactile Pressure-Indicating Sensor Film Helps Capacitor Manufacturer Hold Tighter Product Tolerances news release has been viewed 1312 times
Facility Closure
