  • Undetected Pressure Variations in Flip Chip Assembly Reduce Yields and Raise Costs
Dec 22, 2009
Pressurex Reveals a Pressure Profile Across the Surface of a Flip Chip Bonder
Undetected bonding pressure variations can result in poor or open flip chip connections, reducing yield and long-term reliability while raising costs. Maintaining a uniform distribution of bonding pressure across a flip chip die assures chip to substrate coplanarity, optimal bump compression, and a controlled, reproducible die to substrate gap. Pressurex® pressure indicating sensor film is a valuable assist to today’s flip chip bonders which lack the capability to measure pressure variations across the bonding tool but instead rely on average pressure with the assumption that it is uniformly distributed. Now a proven control measure in wafer-to-wafer bonding, Pressurex® could extend similar low-cost coplanarity and uniformity control to flip chip bonding.
Pressurex® pressure-indicating sensor film provides a convenient, accurate, repeatable, and low cost control for both bonding and coplanarity. The thin flexible sensor film reveals pressures from 2 - 43,200 PSI (0.14 - 3,000 kg/cm2). When placed between the contacting surfaces of a flip chip bonder, it instantaneously and permanently changes color directly proportional to the amount of pressure applied. The precise pressure magnitude and distribution is then easily determined by comparing color variation results to a color correlation chart (conceptually similar to interpreting Litmus paper).
For further information and a complimentary sample of Pressurex® film in your desired range, contact Sensor Products Inc. at 1.973.884.1755 (USA), email info@sensorprod.com or visit http://www.sensorprod.com/sample. All products and applications can be viewed online.
About Sensor Products Inc.
Headquartered in New Jersey and established in 1990, Sensor Products Inc. is a world leader in the manufacture and distribution of tactile pressure sensing solutions. Their customized and off-the-shelf products are installed within all of the Fortune 500 industrial companies as well as thousands of smaller manufacturing firms. Their sensors are used in applications as diverse as tire testing to semiconductor manufacturing and from R&D labs to space missions. Additionally, Sensor Products provides in-house and on-site stress and pressure mapping analysis, as well as a variety of regional technical seminars.
Feb 19, 2010 -
Use of Pressurex Pressure Indicating Sensor Film Increases Bond Strength and Reduces Defects in Ultrasonic Welding of Electronics
Aug 09, 2009 -
Pressurex® Film Promotes Uniform Nip Pressure Distribution to Reduce Dry Film Resist PCB Lamination Defects
Nov 06, 2008 -
New Pressurex Zero� Sensor Film Measures and Maps Very Low Contact Pressures
Oct 16, 2007 -
Unique Tactile Pressure-Indicating Sensor Film Helps Capacitor Manufacturer Hold Tighter Product Tolerances
Dec 20, 2024 -
ViTrox Welcomes Gemaddis as a New Sales Channel Partner in France
Dec 19, 2024 -
ViTrox Expands Innovation Beyond AOI, SPI, and AXI with ViE's VisionXpert Solution
Dec 11, 2024 -
New! Model WDS-900 PC Controlled BGA Rework Station
Dec 11, 2024 -
I.C.T Launches High-Flexibility SMT Line for Efficient and Scalable Electronics Manufacturing
Dec 10, 2024 -
Jabil Recognizes Koh Young with the 2024 Best Strategic Supplier Award
Dec 10, 2024 -
The Three Types of Conveyor: A Comprehensive Guide to Conveyor Rollers and More
Dec 09, 2024 -
ViTrox Expands Midwest Reach with ASC International as New Sales Channel Partner
Dec 09, 2024 -
VJ Electronix to Exhibit at SMTA Silicon Valley Expo & Tech Forum
Dec 09, 2024 -
See You at IPC APEX EXPO 2025
Dec 02, 2024 -
PDR Offers Advanced Infrared Heating Technology for BGA Rework
Undetected Pressure Variations in Flip Chip Assembly Reduce Yields and Raise Costs news release has been viewed 1385 times
Cost-effective Conformal Coating Machine
