New Agilent Technologies Acqiris Digitizers Give Users More
Feb 22, 2008
Agilent Technologies Inc. (NYSE: A) has introduced two new options for its compact, low-power (less than 15 W), high-speed Acqiris 8-bit PCI digitizer to give users more options depending on specific application and budget requirements.
The U1071A-002 model option is an entirely new version of the PCI digitizer product introduced in 2007. It provides the exceptional 8-bit, dual-channel data conversion operation of its original, with up to 2 GS/s sampling rates and a reduced analog bandwidth of 500 MHz guaranteed.
Designed for applications with intense data-acquisition requirements, the new memory options provide up to 256 Msample of acquisition memory, or 128 Msample per channel in two-channel mode. This enables the acquisition of up to 130 ms of data at the full 2 GS/s data rate. At the slowest acquisition rate of 100 S/s, the card provides up to four weeks of continuous data acquisition. Two additional memory options are available: 256 MSample and 64 MSample, which are compatible with the original 1 GHz version and the new 500 MHz version of the digitizer.
Specific uses of the Agilent U1071A include time-of-flight measurements for ranging and inspection applications such as lidar and ultrasound, as well as production testing of semiconductor components and systems including hard disk drive testing.
Designed in a short PCI-card format, the digitizer can be used in all standard PCI bus slots, whether long or short. By combining data-converter ASIC technology with a high level of component integration, the board, without memory options, consumes less than 15 W.
The 1 GHz version of the digitizer incorporates a unique option for simultaneous acquisition and readout (U1071A-SAR). This digital data-handling mode significantly improves measurement throughput. By separating the on-board memory into multiple buffers, data is acquired into one buffer while previously acquired data can be read out through the 32-bit/66 MHz PCI interface. In applications where the total data rate of the acquisition is below the PCI data bandwidth, the U1071A with SAR mode can continuously acquire, missing zero events.
The Agilent U1071A was the first PCI product to feature the proprietary, high-bandwidth auto-synchronization bus system that distributes both the clock and trigger signals among all the digitizers that participate in the system. This enables the synchronization of multiple digitizers when more than two data-acquisition channels are required. Any digitizer channel within the system can then be used to accept a trigger for acquisition across the whole system.
Software drivers for Windows(tm), Linux, LabViewRT and VxWorks enable the U1071A to easily integrate into existing measurement systems as well as to be exchanged, replaced or upgraded to the latest high-speed Acqiris digitizer with minimal software adjustments. In addition, application code examples are included for MATLAB(r), C++, VisualBasic, LabView and LabWindows.
High-resolution photos are available http://www.agilent.com/find/U1071A_image.
U.S. Pricing and Availability
The Agilent U1071A Acqiris 8-bit High-Speed PCI Digitizer is available now. Pricing starts at $5,300. More information about the Agilent U1071A is available at http://www.agilent.com/find/acqiris.
Acqiris Digitizers from Agilent Technologies
Agilent now offers the Acqiris line of products, which includes CompactPCI, PCI, PXI, VXI, VME and OEM digitizers, time-to-digital converters and waveform analyzers with high resolution and high-speed performance.
The Acqiris product line has been designed to provide superior measurement fidelity, minimum power consumption, reduced size and maximum data throughput. It complements Agilent's current product portfolio and strengthens Agilent's synthetic instrument offerings.
For more information on the Acqiris line of products, please visit http://www.agilent.com/find/acqiris.
About Agilent Technologies
Agilent Technologies Inc. (NYSE: A) is the world's premier measurement company and a technology leader in communications, electronics, life sciences and chemical analysis. The company's 19,000 employees serve customers in more than 110 countries. Agilent had net revenues of $5.4 billion in fiscal 2007. Information about Agilent is available on the Web at http://www.agilent.com.
Jan 08, 2014 -
Agilent Technologies Reveals Name of Electronic Measurement Spin-Off Company
Jun 29, 2010 -
Agilent gets serious about JTAG test
Jun 20, 2009 -
Agilent Technologies' Digital Measurement Forum Focuses on Trends Influencing Future of Industry
Feb 15, 2009 -
Agilent Technologies Presents the 2009 Aerospace Defense Symposium "Focus Where it Counts"
Jan 21, 2009 -
Agilent Technologies' New Solder Paste Inspection System Available Feb. 15
Dec 06, 2008 -
Agilent Technologies Displays Comprehensive Femtocell Testing Capability
Nov 19, 2008 -
Agilent Technologies, Solution Sources Programming Announce Additional In-Circuit Test Capacity at Solution Sources
Oct 01, 2008 -
Agilent Technologies to Present Advances in Limited Access Test Solutions at International Test Week
Sep 24, 2008 -
Agilent Technologies, Altron Inc. Announce Altron's Selection of Agilent Medalist sj5000 AOI System
Sep 08, 2008 -
Agilent Technologies' New 10 MHz Function/Arbitrary Waveform Generator Provides High-Quality Waveforms at Economical Price
85 more news from Agilent Technologies, Inc. »
Jun 05, 2024 -
Jun 05, 2024 -
Jun 04, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
New Agilent Technologies Acqiris Digitizers Give Users More news release has been viewed 908 times
