  • Viscom Quality Uplink – The five steps for effective process control
Oct 10, 2013
The Viscom Quality Uplink ensures quality along the line
Productronica, hall/stand A2-177
Effectiveness not only plays an important role in purchasing, logistics and workflows, but a decisive competitive advantage also is achieved in respect to the inspection concept and the use of AOI and AXI systems by linking information. The Viscom Quality Uplink successfully links SPI, AOI, AXI and MXI. This prevents human false accepts, reduces manufacturing costs and increases the first-pass yield.
The Viscom Quality Uplink features a closed-loop connection to the paste printer. This allows the SPI to initiate an automated correction of the solder paste printing or optimize cleaning cycles. Additionally, Viscom offers verification of the stencil design in the framework of program generation. The forward loop of the automatic correction of component placement also is possible. When viewing the 3-D SPI in the direction of the end-of-line process, the Quality Uplink makes it possible to optimize the SMT process in five steps by linking SPI information with post-reflow AOI, AXI or MXI.
Step 1: Image Uplink — In the first step, the SPI defect patterns are transferred as a bitmap to the post-reflow classification station. After the AOI defect verification, the SPI-only defects are subsequently displayed as well. These are the defects that were detected on the SPI but were no longer noticeable on the AOI since they were corrected during the process. Here, the Image Uplink helps the operator to verify the displayed soldered connection.
Step 2: With the Paste Uplink, Viscom offers the option of displaying the results of the paste inspection in the framework of the AOI or AXI defect classification. For all soldered connections of an affected component ID, the 3-D and 2-D paste information and features are available, regardless of the SPI inspection result. Additionally, the information from all adjacent soldered connections can be called up, avoiding misclassifications (human false accepts) to the greatest possible extent when the result of the solder joint inspection is verified.
Step 3: With the Solder Uplink, additional images of the finished soldered connection for SPI-only defects and/or SPI limit defects are provided automatically. A feature of the Viscom 3-D SPI is used to generate so-called ‘warnings.’ In addition to the categories 'certainly good' and ‘certainly bad,’ there is the group of ‘paste application in the limit range,’ which is especially relevant for paste printing. These views can be recorded orthogonally, angled, in 2-D and 3-D, and in color. Together, with the detailed information from the SPI, they provide clear indications of how certain irregularities have behaved after soldering. The additional images can come from the AOI as well as the AXI or MXI. This comparison makes it easy to develop the optimum inspection strategy and optimally use resources.
Step 4: TITUS Uplink — As previously mentioned with the Solder Uplink, Viscom distinguishes between marginal defects and definitive real defects, i.e. specification violations, in the paste inspection. Both limits can be defined independently of one another according to the component type. Depending on the paste measurement values, the TITUS Uplink can be used to define the inspection strategy online, while taking the AOI inspection into consideration. For example, the rules can be defined in relation to products or components. The configuration takes place on the Viscom SPI and determines rules such as which inspection step is addressed and when. Depending on the inspection result, particular inspection steps can be eliminated or activated, resulting in false call reduction, improved quality and increased efficiency.
Step 5: All relevant AOI, SPI, MXI and AXI data can be saved for later process analysis and quality optimization with the Process Uplink. Using the Viscom Uplink Process Analyzer (VUPA), all defects that have occurred can be subsequently analyzed on an offline PC. The functions offer direct conclusions about the soldering result and the corresponding paste inspection results. Therefore, the Process Uplink can directly help define optimized defect limits. The advantages include cost reduction, process and quality optimization and complete documentation.
Finally, the wide product range of Viscom systems makes it possible to include the inspection results of the MXI systems (off-line X-ray inspection) in the uplink in addition to the AOI and AXI results. All inspection data from the Viscom 3-D solder paste inspection can be displayed at the verification station and compared with the images of the X-ray inspection.
The Viscom Quality Uplink makes it possible to better understand process limits and link all inspection data and results in such a way that they are available where they are needed. This conserves valuable resources and optimizes manufacturing costs.
Viscom AG develops, manufactures and sells high-quality inspection systems. The portfolio encompasses the complete bandwidth of optical and X-ray inspections. In the area of assembly inspection for electronics manufacturing, the company is among the leading suppliers worldwide. Viscom systems can be configured specific to the customer and can be interlinked. The company headquarters and manufacturing location is in Hanover, Germany. With a wide network of branches, applications centers, service support points and representatives, Viscom is represented internationally. Founded in 1984, Viscom has been listed on the Frankfurt Stock Exchange (ISIN: DE0007846867) since 2006.
For additional information, visit www.viscom.de.
Dec 25, 2023 -
Viscom to Showcase Inspection of Electronics for Different Customer Requirements at NORTEC 2024
Dec 11, 2023 -
iS6059 PCB Inspection Plus Wins Mexico Technology Award
Oct 23, 2023 -
Fast Double-Sided Inspection from Viscom at productronica 2023
Oct 16, 2023 -
Various Facets of Artificial Intelligence at the Viscom Technology Forum 2023
Oct 16, 2023 -
Viscom Places Special Focus on Networking Topics at SMTA Mexico 2023
Oct 09, 2023 -
Advanced Quality Control from Viscom at NEPCON Asia 2023 in Shenzhen
Sep 04, 2023 -
Inspection Technologies from Viscom at NEPCON Vietnam
Aug 29, 2023 -
Innovative Inspection Technologies from Exacom at the Battery Show North America
Aug 29, 2023 -
Viscom Inc. Exhibiting at SMTA International 2023
Dec 07, 2022 -
Viscom's Newest Inspection Technologies at IPC APEX EXPO 2023
141 more news from Viscom AG »
Aug 01, 2024 -
JONATHAN BEAUDEAU SLANDERED!
Jul 29, 2024 -
SMTA International Technical Conference Program Announced
Jul 29, 2024 -
Jul 29, 2024 -
Murray Percival Company Expands Product Line with Representation of BIMOS ESD Seating in the Midwest
Jul 29, 2024 -
Jul 29, 2024 -
PEMTRON Announces Partnership with American Tec for Distribution in China
Jul 29, 2024 -
Jul 26, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Viscom Quality Uplink – The five steps for effective process control news release has been viewed 983 times
