Selective Soldering s X-Y robotic system offers full process flexibility and high throughput via its �smart� sub-system set-up. Flexible SecureGrip systems in combination with a programmable MultiFlux minimize the need for customized tooling and applications. Multiple preheat zones address the need for higher preheat requirements without impacting cycle times. Combined MultiWave soldering and SelectWave soldering provides optimum balance between high throughput and full flexibility. Like other Vitronics Soltec soldering systems, it is engineered to provide a high degree of flexibility for minimal down time, easy maintenance, low cost of ownership, and quick and easy reconfigurability.
Selective Soldering consists of two soldering stations � SelectWave and MultiWave - that can be configured four different ways, a degree of soldering station flexibility unprecedented in the industry. The combination of MultiWave, for reducing cycle time, and SelectWave, for highest soldering accuracy and flexibility, creates a powerful processing team that sets Selective Soldering apart from competitive systems.
The SelectWave is equipped with a single solder nozzle blanketed by a constant flow of nitrogen, which virtually eliminates maintenance and ensures a stable, clean solder wave. Wave stability is controlled by a unique impeller design working in conjunction with a patented �smart� duct system. A robust stainless steel pump with proven shaft sealing technology ensures low maintenance, high up-time and a stable soldering process. Frequency-controlled reluctance synchronous motors ensure a highly stable pump speed. The unit can operate at temperatures up to 400 �C., ensuring lead-free soldering capability. Solder height is measured and controlled. For more information, contact VITRONICS SOLTEC BV, Karolusstraat 20, 4903 RJ Oosterhout, the Netherlands, Tel. +31-162-483000, Fax +31-162-483253. Internet: http://www.vitronics-soltec.com.
