Critical subsystems such as fluxer, preheat, or wave are easily interchangeable. Its Windows� NT graphical user interface is the standard operating system and makes machine settings, control, and maintenance scheduling fast and easy. Fluxers can be changed in seconds, with a choice of foam and spray nozzle systems. In addition, the temperature compensated electronic flux specific gravity (SG) measurement system ensures repeatable and precise flux chemistries.
When production requirements change, a different heater bank can be field retrofitted in seconds. The preheater can be configured with any combination of forced convection, medium wave IR, or long wave IR calrod emitters. Each heating unit is controlled and has heat-guiding plates to maintain even heat distribution from edge to edge. The solder wave can be easily converted into Double Wave, Smart Wave or Combi Wave.
The Delta Wave Soldering system is designed with a complete array of options and can be customized to fit any soldering application or chemistry. For more information, contact VITRONICS SOLTEC BV, Karolusstraat 20, 4903 RJ Oosterhout, the Netherlands, Tel. +31-162-483000, Fax +31-162-483253. Internet: http://www.vitronics-soltec.com.
