  • Preview Pickering Electronics at Semicon West USA, San Francisco, Booth # 6177
Jun 24, 2014
The SERIES 104 fits on a Board area of 0.25 x 1.0 inches.
The Reed RelayMate is an in-depth new publication which looks in detail at Reed Relays. It describes how reed relays are constructed, what types they are, how they work.
Pickering Electronics are acclaimed Manufacturers of high quality Reed Relays for Instrumentation and Automatic Test Equipment (ATE), High voltage switching, Low thermal EMF, Direct drive from CMOS, RF switching and other specialist applications. Relays are available in Surface Mount, Single-in-Line (SIL), Dual-in-Line (DIL) and many other popular package styles.
Our High quality reed relays are encapsulated using a soft inner material to greatly reduce physical stresses on the glass/metal seal of the reed switch capsule. Different materials have different expansion characteristics and the very hard compounds used by most manufacturers can cause stresses that can damage seals or distort the reed switch thereby changing switch blade alignment. This will degrade contact resistance stability and life expectation.
Pickering Electronics will highlight the following products amongst others at Semicon West 2014 in booth 6177:
If you need Reed Relays for High Voltage applications customers should take a look at Pickering’s High Voltage Relays.
SERIES 104
The SERIES 104 fits on a Board area of 0.25 x 1.0 inches (1 Form A)
They are available up to 3 Kilovolts with Rhodium plated, vacuum switches in a Single-in-Line plastic package. Three voltage ratings are available.
1kV stand-off, 500 volts switching at 10 Watts (One or two Form A or one Form B).
1.5kV stand-off, 1kV switching at 10 Watts (One or two Form A or one Form B).
3kV stand-off, 1kV switching at up to 20 Watts (One Form A only).
Like all of our Single-In-Line Series they are constructed using our SoftCenter™ technology.
SERIES 60/65 fit on a Board area of 0.65 x 2.3 inches
These are available up to 15 Kilovolts with Tungsten plated, vacuum switches.
Series 60 are for chassis mounting with solder tag connections, Series 65 are for PCB mounting. Three voltage ratings are available.
5kV stand-off, 3.5kV switching at 50 Watts (One Form A or one Form B).
10kV stand-off, 7.5kV switching at 50 Watts (One Form A or one Form B).
15kV stand-off, 12.5kV switching at up to 50 Watts (One Form A only).
SERIES 62/63 fit on a Board area of 0.8 x 2.55 inches
These are available up to 15 Kilovolts with Tungsten plated, vacuum switches in a chassis mounting package with push-on connections. Three voltage ratings are available.
Guarantee of High Technical Standards - Pickering Electronics’ Quality Assurance
Pickering manufactures Reed Relays for instrumentation applications using only the highest quality materials. We are certified to ISO 9001-2008 and audited by the British Standards Institution. Pickering relays are subjected to continuous inspection during the manufacturing process and after a strenuous thermal cycling routine are 100 percent tested for all operating parameters on Automatic Test Equipment (ATE) and other specialized equipment. All ATE test results are archived and used for Statistical Process Control.
Featuring Pickering SoftCenter® Technology
We are manufacturers of high quality Reed Relays for Instrumentation and Automatic Test Equipment (ATE), High voltage switching, Low thermal EMF, Direct drive from CMOS, RF switching and other specialist applications. Pickering Relays are available in Surface Mount, Single-in-Line (SIL), Dual-in-Line (DIL) and many other popular package styles and like our existing relays they incorporate SoftCenter® technology.
More about SoftCenter®
Pickering Reed relays are encapsulated using a soft inner material to greatly reduce physical stresses on the glass/metal seal of the reed switch capsule. Different materials have different expansion characteristics and the very hard compounds used by most manufacturers can cause stresses that can damage seals or distort the reed switch thereby changing switch blade alignment. This will degrade contact resistance stability and life expectation.
Pickering Electronics - the Reed RelayMate -
An in-depth new publication which looks in detail at Reed Relays.  It describes how reed relays are constructed, what types they are, how they work. Also our relay experts describe what parameters can affect their operation, how clients can chose the correct relay and furthermore a comparison with other relay technologies and how to drive and place reed relay coils.
The Reed RelayMate is available free of charge from the page of Pickering Electronics’ website and is available as printed copy of PDF format.  We also have copies for you available at Semicon West.
More information is available on our web site www.pickeringrelay.com
Pickering Electronics was formed in 1968 to design and manufacture high quality reed relays, intended principally for use in instrumentation and automatic test equipment. Pickering Electronics offer an extensive range of high quality instrumentation grade reed relays designed for applications requiring the highest levels of performance and reliability. Through the experience of supporting the most demanding manufacturers of large ATE systems with high relay counts Pickering has refined its design, assembly and quality control methods to optimise its product range to this most challenging market.
Jun 29, 2017 -
Sep 22, 2016 -
Jun 27, 2016 -
Oct 05, 2015 -
Oct 05, 2015 -
Sep 08, 2015 -
Aug 18, 2015 -
Jul 08, 2015 -
Dec 01, 2014 -
Sep 18, 2014 -
Aug 16, 2024 -
Brooks Automation - Intrinsic Quality Partnership Announcement
Aug 16, 2024 -
New Business Region
Aug 14, 2024 -
Aug 14, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Preview Pickering Electronics at Semicon West USA, San Francisco, Booth # 6177 news release has been viewed 1105 times
Manufacturing Software
