  • New high voltage Micro-SIL Reed Relays to be released at SEMICON West 2015
Jul 08, 2015
Pickering Electronics are releasing their new Series 119 range for up to 3kV at Semicon West 2015. This will be the industry’s smallest high voltage Single-In-Line Reed Relay available. The relay is intended for voltages considerably higher than standard small SIL relays, ideal for Cable and Backplane Testers, Mixed signal ATE or other applications where High Voltage capability is required.
The vacuumed sputtered ruthenium reed switches have a superb low level performance also, making them an ideal choice where a wide range of signals are involved. The range is based on the long established Series 109P style of plastic package with an internal mu-metal magnetic screen, allowing for high packing density. All Pickering Reed Relays have full magnetic screening which permits side by side operations. The Series 119 is also made using Pickering’s unique SoftCenter® construction.
Four versions are available, all with either 3, 5 or 12 volt operating coils. The 1 Form A, 1kV version has a package and pin configuration compatible with the Pickering’s standard 109P Reed Relay, i.e. 4 pins on 0.15 inches (3.8mm) pitch. These can be stacked side-by-side for maximum packing density. The other types have package lengths and pin configurations appropriate for their voltage ratings.
Pickering Electronics are worldwide manufacturers and distributors of instrumentation grade Reed Relays for ATE, Low thermal EMF, RF switching and other specialist applications. The relays available in Surface Mount, Single-in-Line (SIL), Dual-in-Line (DIL) and many other popular package styles.
The company has seen a large boost in sales in the first two quarters of 2015, which can only be due to their high quality, innovative product offerings, along with good technical support services, and custom designed products. Research suggests this growth is set to continue for the balance of 2015.
To find out more about the new 119 Series High Voltage Micro-SIL Reed Relay visit Pickering on booth no. 6367 in the North Hall at Semicon West 2015, or alternatively go to pickeringrelay.com.
Jun 29, 2017 -
Sep 22, 2016 -
Jun 27, 2016 -
Oct 05, 2015 -
Oct 05, 2015 -
Sep 08, 2015 -
Aug 18, 2015 -
Dec 01, 2014 -
Sep 18, 2014 -
Sep 17, 2014 -
Jul 16, 2024 -
Jul 16, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
New high voltage Micro-SIL Reed Relays to be released at SEMICON West 2015 news release has been viewed 1222 times
