METALNOX® M6960 is an industrial vapor cleaning solvent designed for use in standard vapor degreasing equipment as a drop-in replacement for chlorinated solvents. M6960 is used as received for the removal of typical industrial soils including stamping, drawing, forming and hydraulic oils, buffing compounds, greases, and shop dirt from ferrous and non-ferrous substrates.
METALNOX® M6960 has superior performance characteristics over other brominated-based cleaning solvents due to its unique stabilizer package that allows for longer bath life.
METALNOX® M6960 concentration should be monitored and maintained on a routine and regular basis depending on tank use. Best results are obtained with an Acid Acceptance Test Kit available from Kyzen.
Kyzen® Booster 6 is available for sump adjustment as required for prolonged bath life.
METALNOX® M6330 is a high alkaline aqueous solution designed to clean and brighten a wide variety of metal parts. M6330 will provide long-term corrosion protection on ferrous and copper based alloys, including brass and bronze. M6330 is intended to be diluted for use in spray or immersion systems.
METALNOX® M6330 is particularly effective in removing heavy greases and oils found in typical CNC machining operations. M6330 will not discolor sensitive metals such as brass and other copper based alloys. Aluminum alloys should be tested to determine compatibility.
A non-flammable, corrosive, low VOC aqueous solution, METALNOX® M6330 has proven compatible with most materials of construction used in industrial parts cleaning systems and processes. METALNOX® M6330 contains no CFCs or HAPs.
METALNOX® M6960 is available in 50 and 550 lb containers. METALNOX® M6330 is available in one, five, and 55 gallon containers.
Kyzen® and METALNOX® are registered trademarks in the United States of Kyzen Corporation.
Kyzen is a leading supplier of precision cleaning chemistries to the worldwide electronics, metal finishing, medical, semiconductor, and optical industries. Founded in 1990, Kyzen offers superior cleaning chemistries, technical support, application and analytical services throughout the world. Kyzen has won numerous industry awards for their exceptional products and all products are RoHS compliant. For more information, visit http://www.kyzen.com.
