CYBERSOLV®141-R is designed for optimum effectiveness on a wide variety of soils typically found in electronics assembly and maintenance cleaning applications including flux, paste, inks, uncured adhesives, waxes, mill markings, greases, oils, fingerprints, etc.
CYBERSOLV®141-R can be used as a replacement for HFC 141B precision cleaning applications, and is safe and effective to use for bench top electronics cleaning. 141-R has proven compatible with all materials commonly used in electronics assembly manufacturing and cleaning processes. A biodegradable non-flammable non-corrosive aqueous solution, CYBERSOLV®141-R contains no CFCs or HAPs.
CYBERSOLV® 141-R is available commercially in cases containing 12 aerosol cans.
METALNOX® M6432 is a neutral pH cleaning chemistry designed to be effective on a variety of industrial soils including oil, grease, light oxides and buffing compound. M6432 is used in both spray and immersion processes, and can be run in spray systems at process temperatures as low as 100°F, without foam.
METALNOX® M6432 is a worker-safe product that will not tarnish or etch aluminum, brass or any of the copper-based alloys. M6432 is currently used across many industries, ranging from medical implants to automotive applications. It contains rust inhibitors and can be used at low levels in a rinse stage to prevent flash corrosion of steel. METALNOX® M6432 is an effective cleaner for many manufacturing soils, and typically is used at concentrations ranging from 4-10 percent.
METALNOX® M6432 is available in one, five, and 55 gallon containers.
Kyzen®, CYBERSOLV® and METALNOX® are registered trademarks in the United States of Kyzen Corporation.
Kyzen is a leading supplier of precision cleaning chemistries to the worldwide electronics, metal finishing, medical, semiconductor, and optical industries. Founded in 1990, Kyzen offers superior cleaning chemistries, technical support, application and analytical services throughout the world. Kyzen has won numerous industry awards for their exceptional products and all products are RoHS compliant. For more information, visit http://www.kyzen.com.
