  • Kyzen to Highlight METALNOX® M6330 and METALNOX® M6319 at the 2010 Process Cleaning Expo
Apr 19, 2010
NASHVILLE — April 2010 — Kyzen, the world leading provider of environmentally responsible cleaning products for high reliability and high-technology manufacturing operations, will feature METALNOX® M6330 and METALNOX® M6319 in booth 101 at the upcoming Process Cleaning Expo, scheduled to take place May 4-6, 2010 at the Kentucky International Convention Center in Louisville, KY.
METALNOX® M6330 is a high alkaline aqueous solution designed to clean and brighten a wide variety of metal parts. M6330 will provide long-term corrosion protection on ferrous and copper based alloys, including brass and bronze. M6330 is intended to be diluted for use in spray or immersion systems.
METALNOX® M6330 is particularly effective in removing heavy greases and oils found in typical CNC machining operations. M6330 will not discolor sensitive metals such as brass and other copper based alloys. Aluminum alloys should be tested to determine compatibility.
A non-flammable, corrosive, low VOC aqueous solution, METALNOX® M6330 has proven compatible with most materials of construction used in industrial parts cleaning systems and processes. METALNOX® M6330 contains no CFCs or HAPs.
METALNOX® M6319 is a heavy-duty aqueous high alkaline all-purpose cleaner. It is an aqueous blend of detergents, alkalinity builders, conditioners, and organic and inorganic inhibitors designed for heavy-duty cleaning of oils, waxes, grease, drawing oils, machining oils, fingerprints, hydraulic fluids, road dirt, carbonized oils, petrolatum and shop dirt while being relatively safe to use on most alloys.
M6319 is easy to use, and is diluted further with water as required to remove the soils involved. To prevent flash rusting of ferrous parts, one to three percent of M6319 or an inhibitor may be added to all rinse stages.
The cleaner is low foaming, non-phosphated, and is safe on magnesium as well as ferrous and copper alloys. It features trace silicates, prevents flash rust, and has no HAPs, CFCs or SARA 313s. Additionally, M6319 is low VOC and can be used in both spray and immersion systems.
M6319 is multi-metal safe for use on yellow metals including copper, bronze and brass, some aluminum alloys, iron, steel, and composites in addition to most precious metals, plastics and rubbers.
METALNOX® M6330 and M6319 are available in one, five, and 55 gallon containers.
Kyzen® and METALNOX® are registered trademarks in the United States of Kyzen Corporation.
Kyzen is a leading supplier of precision cleaning chemistries to the worldwide electronics, metal finishing, medical, semiconductor, and optical industries. Founded in 1990, Kyzen offers superior cleaning chemistries, technical support, application and analytical services throughout the world. Kyzen has won numerous industry awards for their exceptional products and all products are RoHS compliant. For more information, visit http://www.kyzen.com.
Jul 01, 2024 -
KYZEN Welcomes Michael McCutchen as Director of Global Sales
Jun 24, 2024 -
KYZEN Introduces Jayson Moy as Product Line Director
Jun 17, 2024 -
KYZEN to Showcase Multi-Process Power Module Cleaner at SEMICON West 2024
Jun 10, 2024 -
Jun 10, 2024 -
May 27, 2024 -
May 27, 2024 -
May 20, 2024 -
KYZEN to Showcase Advanced Packaging Solutions at PCIM Europe 2024
May 13, 2024 -
KYZEN's Adam Klett to Keynote at SMTA Electronics in Harsh Environments Conference
May 06, 2024 -
KYZEN to Highlight AQUANOX A4618 and ANALYST2 at SMTA Rocky Mountain Expo and Tech Forum
604 more news from KYZEN Corporation »
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 09, 2024 -
Kyzen to Highlight METALNOX® M6330 and METALNOX® M6319 at the 2010 Process Cleaning Expo news release has been viewed 840 times
