  • Kyzen to Highlight METALNOX® M6330 and METALNOX® M6319 at EASTEC 2010
May 11, 2010
NASHVILLE — Kyzen, a world leading provider of environmentally responsible cleaning products for high reliability and high-technology manufacturing operations, will feature METALNOX® M6330 and METALNOX® M6319 in booth 3021 at the upcoming EASTEC Advanced Productivity Exhibition, scheduled to take place May 25-27, 2010 at the Eastern States Exposition Grounds in West Springfield, MA.
METALNOX® M6330 is a high alkaline aqueous solution designed to clean and brighten a wide variety of metal parts. M6330 will provide long-term corrosion protection on ferrous and copper based alloys, including brass and bronze. M6330 is intended to be diluted for use in spray or immersion systems.
METALNOX® M6330 is particularly effective in removing heavy greases and oils found in typical CNC machining operations. M6330 will not discolor sensitive metals such as brass and other copper based alloys. Aluminum alloys should be tested to determine compatibility.
A non-flammable, corrosive, low VOC aqueous solution, METALNOX® M6330 has proven compatible with most materials of construction used in industrial parts cleaning systems and processes. METALNOX® M6330 contains no CFCs or HAPs.
METALNOX® M6319 is a heavy-duty aqueous high alkaline all-purpose cleaner. It is an aqueous blend of detergents, alkalinity builders, conditioners, and organic and inorganic inhibitors designed for heavy-duty cleaning of oils, waxes, grease, drawing oils, machining oils, fingerprints, hydraulic fluids, road dirt, carbonized oils, petrolatum and shop dirt while being relatively safe to use on most alloys.
M6319 is easy to use, and is diluted further with water as required to remove the soils involved. To prevent flash rusting of ferrous parts, one to three percent of M6319 or an inhibitor may be added to all rinse stages.
The cleaner is low foaming, non-phosphated, and is safe on magnesium as well as ferrous and copper alloys. It features trace silicates, prevents flash rust, and has no HAPs, CFCs or SARA 313s. Additionally, M6319 is low VOC and can be used in both spray and immersion systems.
M6319 is multi-metal safe for use on yellow metals including copper, bronze and brass, some aluminum alloys, iron, steel, and composites in addition to most precious metals, plastics and rubbers.
METALNOX® M6330 and M6319 are available in one, five, and 55 gallon containers.
Kyzen® and METALNOX® are registered trademarks in the United States of Kyzen Corporation.
Kyzen is a leading supplier of precision cleaning chemistries to the worldwide electronics, metal finishing, medical, semiconductor, and optical industries. Founded in 1990, Kyzen offers superior cleaning chemistries, technical support, application and analytical services throughout the world. Kyzen has won numerous industry awards for their exceptional products and all products are RoHS compliant. For more information, visit http://www.kyzen.com.
Sep 16, 2024 -
KYZEN Wins Two Mexico Technology Awards for KYZEN SLV901 and KYZEN ANALYST²
Sep 16, 2024 -
KYZEN to focus on AQUANOX A4618 and ANALYST2 at SMTA Utah
Sep 09, 2024 -
MICRONOX MX2123 to Lead KYZEN Offerings at The International Symposium on Microelectronics
Sep 09, 2024 -
KYZEN Announces Partnership with Added-Value Distributor ADTOOL Corporation
Aug 26, 2024 -
Adam Klett, KYZEN Director of Science, Re-elected to SMTA Board
Aug 19, 2024 -
KYZEN to Focus on AQUANOX A4618 and Process Control at SMTA Ohio Valley Expo and Tech Forum
Aug 19, 2024 -
KYZEN to Feature KYZEN E5631J and AQUANOX A4618 at SMTA Michigan Expo and Tech Forum
Aug 19, 2024 -
KYZEN Showcases Chemistry and Concentration Monitoring with the New ANALYST2 at SMTA Guadalajara
Aug 12, 2024 -
KYZEN to Focus on AQUANOX A4639 and KYZEN SLV901 at SMTA Long Island Expo and Tech Forum
615 more news from KYZEN Corporation »
Sep 16, 2024 -
Essemtec Wins 2024 Mexico Technology Award for Excellence in Dispensing Technology
Sep 16, 2024 -
Impossible Objects' Flagship Industrial 3D Printer, The CBAM-25 Wins 2024 Mexico Technology Award for 3D Printing
Sep 16, 2024 -
Sep 16, 2024 -
IPC White Paper Calls for Comprehensive Roadmap to Address Advanced Packaging to Board-Level Integration Challenges
Sep 16, 2024 -
Stannol Wins Two Mexico Technology Awards for Flux and Solder Wire Innovations
Sep 16, 2024 -
Author Jairek Robbins to Discuss Leadership and Legacy in the Manufacturing Industry During the Keynote Address at SMTA International and The ASSEMBLY Show
Sep 16, 2024 -
Nordson Test & Inspection Honored with Technology Award for SQ3000M2
Sep 16, 2024 -
Apollo Seiko Mexico Triumphs with the STARGATE Laser Soldering Unit at the 2024 Mexico Technology Awards
Sep 16, 2024 -
Altus Hosts Record-Breaking 'Factory of the Future' Event
Sep 16, 2024 -
SMTVYS Technology's Victor Madero Earns Best Mexico Sales Rep Award
Kyzen to Highlight METALNOX® M6330 and METALNOX® M6319 at EASTEC 2010 news release has been viewed 933 times
