  • Data I/O Announces Partnership with Nuvoton Technology Corporation Japan to Enable Security Deployment Services on the SentriX Platform for M2354 Series Microcontroller Devices
Mar 16, 2023
The SentriX security deployment platform supports hardware-based device security for industrial and consumer applications that deliver trusted data to power new business models.
Data I/O Corporation (NASDAQ: DAIO), the leading global provider of advanced security and data deployment solutions for microcontrollers, security ICs and memory devices, and Nuvoton Technology Corporation Japan partner to enable security deployment services for Nuvoton’s M2354 Series-based IoT Security Microcontroller (MCU) series using Data I/O’s SentriX® security deployment platform. The collaboration enables OEMs designing solutions such as building automation, metering, medical and many other applications with high-security requirements to simplify the deployment of IoT security using Data I/O’s SentriX Product CreatorTM software tool.
New connected device-based revenue models require trusted data and trusted devices to enable data-driven services and to protect physical systems. Protecting and securing device firmware and data requires robust hardware-based security. Traditionally, defining provisioning and deploying IoT device security in mass production has been complex and required disparate tools and processes. The SentriX Product Creator tool simplifies IoT security by delivering pre-configured security deployment profiles for the most popular IoT use cases such as device identity, cloud onboarding, secure boot, firmware encryption, mutual authentication and more. The SentriX Product Creator pre-configured profiles present the most popular security features of the M2354 Series.  Nuvoton’s M2354 Series inherits the security features of the M2351 Series that have PSA Certified Level 1, Level 2, and PSA Functional API Certified. The M2354 Series is an Arm® Cortex®-M23 based IoT Security MCU that leverages Armv8-M TrustZone hardware-enforced isolation. Nuvoton and Data I/O are partnering to enable security deployment services starting with Nuvoton M2354 Series support.  With SentriX support, OEMs can leverage M2354 Series and quickly and cost-effectively deploy the security capabilities through robust provisioning in mass production. The predefined use cases streamline the security product definition process for OEMs by presenting the most common security use cases for connected device security in an intuitive user interface.
“As new services and applications for IoT markets expand, OEMs require a simplified process to define and deploy hardware-based security into their products during manufacturing. We are excited to collaborate with Nuvoton to support the M2354 Series on the SentriX platform,” said Michael Tidwell, vice president of marketing and business development at Data I/O Corporation. “The SentriX security deployment platform enables OEMs to easily define security profiles and provision M2354 Series at the chip level before the device goes to the manufacturing line for board assembly. Because the SentriX platform is scalable and is supported globally through SentriX service provider partners, OEMs with low or high volume can cost-effectively deploy robust IoT security in their products.”
“The M2354 Series is designed to support high-security requirements that are essential for even the most demanding IoT solutions,” said Tomohiro Shimo, vice president at Nuvoton Technology Corporation Japan. “Our collaboration with Data I/O enables our customers to leverage the extensive security features of the M2354 Series. SentriX Product Creator enables our OEM customers to define and build hardware-based security into their products more easily and in less time.”
SentriX GO pre-defined use cases through the SentriX Product Creator tool will be made available for M2354 Series through SentriX Service providers globally by the third quarter 2023.  Data I/O and Nuvoton plan to collaborate and announce support on SentriX Product Creator with pre-defined use cases on additional devices in the future.
About SentriX Security Deployment Platform
SentriX secures the global electronics supply chain and protects IoT device intellectual property from point of inception to deployment in the field. Data I/O’s SentriX security deployment platform provisions security objects and secrets into semiconductor devices for low volume prototyping applications and high-volume production. SentriX integrates a FIPS 140-2 Level 3 compliant HSM into an automated programming system which enables secure provisioning of credentials into security ICs and microcontrollers in high-volume.  SentriX is available as a turnkey provisioning and programming system and Data I/O’s PSV7000 and PSV5000 can also be upgraded in the field to support SentriX security provisioning. SentriX security deployment is also available as a service through SentriX service providers globally. SentriX supports OEMs of any size and securely provisions device volumes from individual samples to high-volume production.
SentriX Product Creator is the software tool suite used by OEMs, silicon vendors and programming facilities to define and collaborate on security features provisioned on SentriX. The SentriX Product Creator tool offers OEMs two flexible security deployment models:  fully customizable and SentriX GO™ pre-configured security profiles saving time, effort and avoiding potential pitfalls during security deployment definition. The profile definitions completed using the SentriX Product Creator tool are secure at rest and transferred for device provisioning on the SentriX security deployment platform at a secure programming location.  SentriX Product Creator is available today.
Learn more about SentriX at www.dataio.com/SentriX or visit Data I/O at embedded world in booth 4-448 in Nuremberg, Germany from March 14th – 16th.
Since 1972, Data I/O has developed innovative solutions to enable the design and manufacture of electronic products for automotive, Internet-of-Things, medical, wireless, consumer electronics, industrial controls, and other electronics devices. Today, our customers use Data I/O security deployment and programming solutions to reliably, securely, and cost-effectively bring innovative new products to life. These solutions are backed by a global network of Data I/O support and service professionals, ensuring success for our customers. For more information, please visit www.dataio.com.
Apr 15, 2024 -
Data I/O Announces Major Milestone with 500th PSV System Sale Ahead of IPC APEX Expo
Mar 18, 2024 -
Data I/O to Showcase Automated Pre-placement Device Programming and Security Provisioning Solutions for the Connected Factory at IPC APEX Expo 2024
Oct 16, 2023 -
Data I/O to Exhibit Industry-Leading Data Programming and Security Provisioning Solutions for Secure and Connected Applications at productronica 2023
Feb 27, 2023 -
Data I/O Announces New SentriX Security Provisioning Services in Japan Through Noa Leading Co., Ltd
Jan 30, 2023 -
Data I/O to Demonstrate 64% Increase in Programming Performance on Lumen®X Programmers and Connected Factory Enablement with ConneX Software at IPC APEX Expo
Apr 28, 2022 -
Data I/O Announces SentriX Customer Deployment in Collaboration with Avnet Silica and NXP using NXP's LPC55S6x Microcontroller Family and SentriX Product Creator
Mar 03, 2022 -
Data I/O Announces Appointment of Edward Smith to Board of Directors
Jan 10, 2022 -
Data I/O Announces Appointment of Dr. Cheemin Bo-Linn to Board of Directors
Nov 22, 2021 -
Data I/O Receives GLOBAL Technology Award for SentriX Product Creator™ Software Tool Suite
Dec 04, 2020 -
Data I/O Announces Support for Infineon OPTIGA™ TPM2.0 on SentriX Product Creator Software Tool Suite
116 more news from Data I/O Corporation »
Jun 04, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
May 31, 2024 -
OMD Types and Techniques
May 30, 2024 -
Data I/O Announces Partnership with Nuvoton Technology Corporation Japan to Enable Security Deployment Services on the SentriX Platform for M2354 Series Microcontroller Devices news release has been viewed 732 times
