  • Data I/O Corporation’s ProLINE-RoadRunner™ Now Supports Panasonic NPM SMT Placement Machines
Feb 02, 2011
Customers with a Panasonic NPM model SMT machine can now plug the ProLINE-RoadRunner directly into the SMT placement machine and program memory devices just before placement on the circuit board.
Data I/O Corporation (NASDAQ: DAIO), the leading provider of manual and automated device programming solutions, today announced support for Panasonic NPM Surface Mount Placement Machines with the ProLINE-RoadRunner™. Customers with a Panasonic NPM model SMT machine can now plug the ProLINE-RoadRunner directly into the SMT placement machine and program memory devices just before placement on the circuit board.
The ProLINE-RoadRunner™ is a high-speed automated inline programming feeder that mounts directly onto an SMT machine without consuming any additional floor space or altering the production line. By removing unprogrammed flash memory devices from tape, the ProLINE-RoadRunner programs four devices in parallel, delivering the programmed parts to the pick-up point of the placement machine.
The ProLINE-RoadRunner is a just-in-time (JIT) inline programming system featuring the FlashCORE III, the world's fastest flash programming architecture available on the market today for programming high-density flash memories such as e.MMC, SD and NAND flash. FlashCORE III is the highest-quality proven solution for programming Microcontrollers, EPROM, EEPROM, NOR Flash and many others.
Data I/O has successfully installed hundreds of RoadRunners for companies wishing to apply lean manufacturing to the programming process. By implementing the JIT programming provided by the RoadRunner, customers are able to eliminate inventory of pre-programmed devices, dramatically reduce inventory carrying and rework costs, and recognize a rapid ROI in only a matter of months.
“Since its introduction more than 10 years ago, the ProLINE-RoadRunner™ has enabled the world’s leading manufacturers of electronics products to streamline their programming process, literally saving millions of dollars while simultaneously increasing the velocity of their production process. The ProLINE-RoadRunner™ is a unique inline programming process that provides a combination of benefits that offline programming and ISP/ICT solutions simply cannot match,” said Carl Olson, Director of Engineering at Data I/O.
The ProLINE-RoadRunner™ can be operated both locally and through a network interface. Design changes can be made as needed and downloaded directly to the RoadRunner’s own IP address. The ProLINE-RoadRunner™ also provides PC Card Support for data and job transfer on Windows 95/98, Windows NT/2000, and Windows-XP. Built-in diagnostics and job statistics are written to the RoadRunner’s PC card and the statistics are saved back to TaskLink, allowing the user to analyze production yields and throughput.
“Support of the Panasonic NPM reflects our decade-long commitment in the continuous investment to the ProLINE-RoadRunner™ Inline programming system. These investments provide leading-edge programming performance that seamlessly integrates into the latest surface mount technology,” said Carl Olson.
The Panasonic NPM (Next Production Modular) provides a completely integrated single-platform solution for expanding and evolving electronics assembly needs. In addition to its interchangeable plug-and-play placement heads, the NPM platform integrates solder paste inspection (SPI), adhesive dispense (ADH) and post-placement inspection (AOI).
The ProLINE-RoadRunner™ is supported on Siemens, Fuji, Panasonic, MYDATA, Assembléon and Universal SMT machines.
For nearly 40 years, Data I/O Corporation has been the world leader in the manufacture, distribution and service of innovative solutions for programmable devices. Since 1972, we have championed the use and growth of programmable devices in a wide variety of industries and products. Today, our customers manufacture millions of products each year using Data I/O programming solutions to reliably, securely, and cost-effectively implement their Intellectual Property into programmable devices. And for the future, virtually every new electronic product produced by OEM, ODM, or EMS facilities represents another potential customer for Data I/O solutions.
In collaborative innovation with our customers, Data I/O provides programming solutions for devices in any package, whether programmed in a socket or on a circuit board. Our expertise in programmable integrated circuits, global supply chain processes, and IP management and protection helps bring innovative new products to life. Data I/O joins in partnership with our customers to provide "Application Innovation" solutions that integrate device management into existing business processes. These solutions are backed by a global network of Data I/O support and service providers, assuring success for our customers.
For further information on Data I/O, please visit http://www.dataio.com
Apr 15, 2024 -
Data I/O Announces Major Milestone with 500th PSV System Sale Ahead of IPC APEX Expo
Mar 18, 2024 -
Data I/O to Showcase Automated Pre-placement Device Programming and Security Provisioning Solutions for the Connected Factory at IPC APEX Expo 2024
Oct 16, 2023 -
Data I/O to Exhibit Industry-Leading Data Programming and Security Provisioning Solutions for Secure and Connected Applications at productronica 2023
Mar 16, 2023 -
Data I/O Announces Partnership with Nuvoton Technology Corporation Japan to Enable Security Deployment Services on the SentriX Platform for M2354 Series Microcontroller Devices
Feb 27, 2023 -
Data I/O Announces New SentriX Security Provisioning Services in Japan Through Noa Leading Co., Ltd
Jan 30, 2023 -
Data I/O to Demonstrate 64% Increase in Programming Performance on Lumen®X Programmers and Connected Factory Enablement with ConneX Software at IPC APEX Expo
Apr 28, 2022 -
Data I/O Announces SentriX Customer Deployment in Collaboration with Avnet Silica and NXP using NXP's LPC55S6x Microcontroller Family and SentriX Product Creator
Mar 03, 2022 -
Data I/O Announces Appointment of Edward Smith to Board of Directors
Jan 10, 2022 -
Data I/O Announces Appointment of Dr. Cheemin Bo-Linn to Board of Directors
Nov 22, 2021 -
Data I/O Receives GLOBAL Technology Award for SentriX Product Creator™ Software Tool Suite
116 more news from Data I/O Corporation »
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
May 31, 2024 -
OMD Types and Techniques
May 30, 2024 -
May 30, 2024 -
Data I/O Corporation’s ProLINE-RoadRunner™ Now Supports Panasonic NPM SMT Placement Machines news release has been viewed 1376 times
Void Free Reflow Soldering
