Practical Components announces that some of its products will be featured by Bob Willis in the Printed Board Assembly Cleaning and Contamination Testing Center during the upcoming IPC APEX Expo, scheduled to take place February 19-21, 2013 at the San Diego Convention Center. Located in Booth #1549, the center will provide practical support to visitors keen to implement new cleaning and contamination monitoring processes as well as overcome reliability failures.
Stop by the Cleaning Center or the Practical Components booth to find out about the great products that are designed to help determine the cleanliness of your manufacturing process.
Some Practical products designed to verify your cleanliness:
PCB052
PCB-SIR
PCB-Saber
PCB-B-24
PCB-B-25A
PCB-B-36
The Printed Board Assembly Cleaning and Contamination Testing Center will demonstrate ionic testing, surface insulation resistance (SIR), solder paste flux cleaning system, cleaning materials, optical inspection, PCB and component compatibility testing, among other processes. The clinic is organized by IPC and National Physical Laboratory.
For more information, stop by booth A16 at the show, call 714-252-0010 or visit www.practicalcomponents.com.
Since 1996, Practical Components has been the world’s leading supplier of dummy components, which are the exact mechanical equivalents of live components, used when only the physical properties of the components are required. These components can cost as much as 80% less than live components, making them ideal for testing of solder processes, machine setup and other process evaluations. Practical Components is headquartered in Los Alamitos CA and has a worldwide distribution network. For more information, visit www.practicalcomponents.com.
