  • Aqueous Technologies to Feature Trident III and Zero-Ion G3 at IPC Midwest 2009
Aug 28, 2009
RANCHO CUCAMONGA, CA — August 2009 — Aqueous Technologies Corp. announces that it will feature its Trident III automatic defluxing and cleanliness testing system, along with its Zero-Ion G3 in booth 411 at the upcoming IPC Midwest Conference & Exhibition, scheduled to take place September 23-24, 2009 at the Renaissance Schaumburg Hotel & Convention Center in Schaumburg, IL.
Trident III is capable of removing all flux residues including rosin, no-clean and water soluble. Both lead and lead-free flux residues may be removed using the system, and it is equipped with an automatic chemical injection system that automatically adds a programmable volume of defluxing chemical to the wash water.
Trident III is equipped with a closed-loop wash solution recycling system. Wash solution is heated automatically and sprayed onto the assemblies. At the end of the wash cycle, the wash solution is directed back to the wash solution holding tank for subsequent reuse. Rinse water is then sprayed onto the assemblies until the desired cleanliness level is achieved. All rinse water is directed through the pre-drain filtration system then sent to drain. Assemblies are dried via the on-board convection and radiant forced air drying system.
Trident III is equipped with a host of standard features including programmable maintenance reminders, remote SPC viewing, SPC data USB export and a built-in chemical management system. An optional zero-discharge evaporation system eliminates connection to a drain line.
The automatic defluxing system is reportedly the fastest batch-format defluxing system available. Trident’s specific throughput rate is determined by board size. The Trident III is capable of defluxing and cleanliness testing up to 200 4 x 6" (101 x 152 mm) boards and up to 28 18 x 20" (457 x 508 mm) boards per hour.
Also on display at the show, the Zero-Ion Ionic Contamination (Cleanliness) Tester is designed to test electronics assemblies for ionic contamination. It automatically removes and detects contamination on an electrical assembly or bare board and provides quantitative contamination measurements. The Zero-Ion uses a dynamic technology that provides automatic regeneration of the machine’s test solution, maintaining a high degree of test solution sensitivity. The Zero-Ion meets the requirements of military and commercial cleanliness testing standards including MIL 2000A, IPC test method 001, MIL-C-28809, MIL-P-55110 and IPC TM650-2.3.26.
The Zero-Ion has been reviewed by the U.S. Naval Air Weapons Center and determined to be the most sensitive ionic contamination tester available. The Zero-Ion also has been determined to be 3.7 times more sensitive than the manual resistivity of solvent extract (R.O.S.E.) test. The Zero-Ion performs cleanliness tests automatically and is capable of storing 50 test parameters within its internal controller.
Mar 24, 2016 -
Oct 21, 2015 -
Oct 13, 2015 -
Aug 10, 2015 -
Jun 24, 2015 -
May 12, 2015 -
May 12, 2015 -
Apr 09, 2015 -
Jan 27, 2015 -
Jan 21, 2015 -
Sep 14, 2024 -
1769-L18ERM-BB1B MOTION Processors
Sep 14, 2024 -
ABB 1KHL016009R0001 NSK5G4AK
Sep 14, 2024 -
SIEMENS 7UT5131-5CB01-1BA0/KL
Sep 14, 2024 -
EPRO PR6424/104-141 CON041
Sep 14, 2024 -
SIEMENS 6DS1122-8AA
Sep 14, 2024 -
NISSEI BS1-N018
Sep 14, 2024 -
ABB DSMC110 57330001-N
Sep 14, 2024 -
BENTLY NEVADA 330104-00-24-10-02-00
Sep 14, 2024 -
LEUZE IFRK 93/4-100 L.2
Sep 14, 2024 -
BENTLY NEVADA 133396-01
Aqueous Technologies to Feature Trident III and Zero-Ion G3 at IPC Midwest 2009 news release has been viewed 1091 times
