Trident III is capable of removing all flux residues including rosin, no-clean and water soluble. Both lead and lead-free flux residues may be removed using the system, and it is equipped with an automatic chemical injection system that automatically adds a programmable volume of defluxing chemical to the wash water.
Trident III is equipped with a closed-loop wash solution recycling system. Wash solution is heated automatically and sprayed onto the assemblies. At the end of the wash cycle, the wash solution is directed back to the holding tank for subsequent reuse. Also equipped with a real-time cleanliness tester, rinse water is then sprayed onto the assemblies until the desired cleanliness level is achieved. All rinse water is directed through the pre-drain filtration system and then sent to drain. Assemblies are dried via the onboard convection and radiant forced air drying system.
Trident III is equipped with a host of standard features including programmable maintenance reminders, remote SPC viewing, SPC data USB export and a built-in chemical management system. An optional zero-discharge evaporation system eliminates connection to a drain line.
The automatic defluxing system is reportedly the fastest batch-format defluxing system available. Trident’s specific throughput rate is determined by board size and cleanliness setting. The Trident III is capable of defluxing and cleanliness testing up to 200 4 x 6" (101 x 152 mm) boards and up to 28 18 x 20" (457 x 508 mm) boards per hour.
Also on display at the show, the Zero-Ion g3 Ionic Contamination (Cleanliness) Tester is designed to test electronics assemblies for ionic contamination. It automatically removes and detects contamination on an electrical assembly or bare board and provides quantitative contamination measurements. The Zero-Ion g3 uses a dynamic technology that provides automatic regeneration of the machine’s test solution, maintaining a high degree of test solution sensitivity. The Zero-Ion meets the requirements of military and commercial cleanliness testing standards including MIL 2000A, IPC test method 001, MIL-C-28809, MIL-P-55110 and IPC TM650-2.3.26.
The Zero-Ion has been reviewed by the U.S. Naval Air Weapons Center and determined to be the most sensitive ionic contamination tester available. The Zero-Ion also has been determined to be 3.7 times more sensitive than the manual resistivity of solvent extract (R.O.S.E.) test. The Zero-Ion performs cleanliness tests automatically and features a Windows PC-based control platform with a 20" LCD interface.
Founded in 1992 and headquartered in Rancho Cucamonga, CA, Aqueous Technologies Corporation is North America's leading manufacturer of aqueous cleaning systems. Aqueous Technologies manufactures both batch-format and inline aqueous cleaning/defluxing systems. Aqueous Technologies also manufactures both ultrasonic and spray-in-air stencil cleaning systems, PCB and stencil cleaning chemistries and the Zero-Ion ionic contamination (cleanliness) tester. Aqueous Technologies’ products have won more than 30 industry awards. Visit the company on the Web at http://www.aqueoustech.com.
