  • Sono-Tek Corporation to Show the New QR Impact Jet on Its Spray Fluxer at productronica
Oct 21, 2015
QR Impact Jet on Its Spray Fluxer.
Sono-Tek Corporation (OTC BB: SOTK) will highlight the QR Impact Jet on the SonoFlux ultrasonic spray fluxer in Hall A4, Booth 141 at the productronica International Trade Fair, scheduled to take place Nov. 10-13, 2015 at the Messe München exhibition center in Munich, Germany. The Impact atomizing assembly is used in both the SonoFlux Servo and SonoFlux EZ system and incorporates an air deflector that drives the flux droplets to the PCB for maximum top side fill and unsurpassed through-hole penetration. The new QR Impact Jet further improves the Impact design with:
  • Improved Lower Maintenance of QR Impact – QR Ryton construction material is non-stick to reduce flux residue buildup. Compared to the stainless steel/titanium Impact Jet, the QR Jet provides approximately double the time between maintenance on the Jet surface.
  • Improved Corrosion Resistance –The QR Impact Jet is made of Ryton, a material with improved chemical corrosion resistance in comparison to stainless steel or titanium, and is high temp heat resistant as well. Ryton will withstand corrosion from ALL wave solder fluxes.
  • Improved Easy Clean Quick Release – The QR design allows the Impact Jet to be easily removed for cleaning with a simple turn of the hand. The stainless steel Impact Jet, in comparison, requires unscrewing the jet, which is time consuming.
  • Improved Accuracy of Spray Pattern – Repeatability of the QR Jet spray pattern is +/-1 degree, compared to +/-8° with the stainless steel/titanium Jet.
  • Improved Fixed Position of QR Impact – The QR design has a fixed, one position, turn-in location, ensuring the jet is always 90° to the PCB. The stainless steel jet must be visually positioned at degrees to the PCB, making it more likely to misalign. The QR fixed position design also prevents overtightening of the jet.
As the world leader in ultrasonic spray fluxing systems, Sono-Tek continues to provide innovative solutions for wave solder manufacturing, with continued world-class service and support of all of its ultrasonic spray fluxing equipment.
Sono-Tek ultrasonic spray fluxers are designed for easy retrofit into all major wave solder machines. Visit Sono-Tek’s website at www.sprayfluxing.com to learn more or email info@sono-tek.com.
Sono-Tek is the world leader in the development and application of liquid ultrasonic atomization technology into nozzle systems and spraying and coating application systems. Compared to conventional pressure spraying methods, the company’s ultrasonic nozzles do not clog, reduce liquid usage, waste, and environmental impact while achieving much more precise, uniform, thin film coatings. Sono-Tek is continually developing new applications for its unique technology, replacing wasteful practices in a world that is growing ever more environmentally sensitive. For more information, visit the company at www.sono-tek.com.
Jun 17, 2024 -
Sono-Tek to Demonstrate SPT200 Photoresist Coating at SEMICON West 2024
Mar 18, 2024 -
Ultrasonic Selective Fluxing System Excels in Efficiency
Jan 23, 2023 -
Sono-Tek Corporation Promotes Ronnie Teo to Technical Sales Manager – Asia Operations
Mar 03, 2022 -
Sono-Tek Announces Next-Generation Fully Inert Glovebox System for Advanced Battery Applications
Feb 07, 2022 -
Sono-Tek Announces New Product for EMI Shielding Spray Coatings
Sep 23, 2021 -
Sono-Tek Uplisted to Nasdaq Capital Market
Mar 25, 2021 -
Sono-Tek Announces the Company's 300th Ultrasonic Spray System Sold for Fuel Cell and H2 Electrolyzer Coating Applications
Jan 15, 2020 -
New Ultrasonic Coating System Advances Spray-On EMI Shielding Capabilities
Jan 08, 2020 -
Sono-Tek Corporation Celebrates 45 Years of Providing Ultrasonic Coating Equipment
Jun 09, 2019 -
Sono-Tek Corporation Promotes Chris Cichetti to Vice President, Applications Engineering
70 more news from SONO-TEK CORPORATION »
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Sono-Tek Corporation to Show the New QR Impact Jet on Its Spray Fluxer at productronica news release has been viewed 1082 times
