  • Reworkable Edgebond Adhesive Improves CBGA and BGA Thermal Cycle Performance and Eliminates Underfill
Apr 07, 2011
Edgebonded CBGA
Edgebonded CBGA
After removal of underfilled BGA, underfill residues must be removed.
Zymet Inc. has introduced a reworkable edgebond adhesive, UA-2605, that improves thermal cycle performance of CBGAs and plastic BGAs. In one trial, UA-2605 tripled the 0°C to +100°C performance of a CBGA, to nearly 2500 cycles. Previously, an underfill was needed to achieve this level of performance.
The edgebond adhesive is much easier to process than an underfill. When applying underfill, the board is preheated to facilitate capillary flow, and multiple dispense passes are used to deposit sufficient material. With UA-2605, only four beads of the adhesive are required, one at each corner (Figure 1). There is no need to preheat the board, no need to wait for underfill flow, no need for multiple dispensing passes.
Reworking an underfilled BGA is a time consuming and delicate task. Underfill residues (Figure 2) must be removed and, for fine pitch BGAs, the risk of pad damage is high. With UA-2605, BGA rework is simple and straightforward. The temperature is raised and the adhesive is scraped away; then, the BGA is reflowed and lifted from the board. Little site cleaning is necessary.
Zymet (http://www.zymet.com) is a manufacturer of microelectronic and electronic adhesives and encapsulants. Its products include die attach adhesives, substrate adhesives, UV curable glob top and cavity-fill encapsulants, and underfill encapsulants.
Feb 08, 2013 -
Zymet Announces Highly Crack Resistant Underfill for Thin, Flexible Assemblies, CN-1751-4
Jan 13, 2012 -
New Underfill from Zymet for 0.4-mm pitch POP's
Mar 17, 2010 -
Low CTE Reworkable Underfill for Superior Thermal Cycle Performance
Sep 17, 2009 -
Reworkable Underfill for Package-on-Package (POP)
Apr 27, 2004 -
Reworkable Underfill Encapsulant for BGA's
Sep 25, 2003 -
Reworkable Underfill Encapsulant for CSP's and BGA's
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Reworkable Edgebond Adhesive Improves CBGA and BGA Thermal Cycle Performance and Eliminates Underfill news release has been viewed 2125 times
