With the market trend moving away from the PCB and towards the standard enclosure, there is an increased need for DIN Rail mounting of products initially designed for PCB applications. With this in mind, the MS11 DIN Rail assembly from Hawco-Crydom has been designed to allow maximum flexibility to assist panel builders and assemblers alike. A full range of PCB mount SSRs are available on the compact DIN Rail assembly. Connections are made through box terminals that will readily accept stripped wire ends and wire pin terminations. At only 12mm wide the MS11 also offers designers the opportunity to utilise smaller panels, enclosures and cabinets. The MS11 can be fitted to an industry standard TS35 DIN Rail.
The MS11 assembly packaged includes a full range of SSRs, catering for the switching of both AC or DC loads in a variety of applications such as control of motors, fans, solenoids, valves and high current contactors. Options include AC or DC control with an input status LED on the DC control models. AC SSRs can switch loads up to 5A at 240V, while the DC SSRs can switch loads of up to 10A at 200 Vdc.
HAWCO Ltd.
