Technic Releases Black Pad Resistant Electroless Nickel
Jan 03, 2012
Typical “Cauliflower” effect (Left)	Technic’s New EN AT5600 (Right)
Technic Inc. has announced the release of  Technic EN AT5600, an electroless nickel developed specifically to eliminate black pad and to improve soldering on ENIG coated PCBs.  Technic EN AT 5600 is the first electroless nickel that provides lateral growth on copper,  yielding a flatter surface with less pronounced grain boundaries instead of the typical nodular, "cauliflower-like" structure from older formulas. This is important, because the grain boundaries are where corrosion products initiate, and under worst case conditions can become black pad.
Technic EN AT 5600 also features a unique additive system that produces excellent solution stability throughout its bath life, eliminating the need for any break-in periods. This provides significant overall cost savings by preventing plate out, increasing bath life and eliminating the use of dummy plating required by other systems. Technic EN AT 5600 has been engineered to provide a cost effective solution while improving soldering and eliminating defects.
Conversion to lead free alloys in electronics has narrowed the operating window on the assembly process making it more important than ever to have a pristine surface for soldering.  By providing a flatter surface, Technic EN AT5600 is the only ENIG process that provides a substantially better surface to solder to.”  - Eric Stafstrom, Technic Global Product Manager
Technic, Inc. is a US based, private, financially strong corporation.  For over 65 years, Technic has been a global supplier of specialty chemicals, custom finishing equipment, engineered powders, and analytical control systems to the electronic component, printed circuit board, semiconductor, photovoltaic, industrial finishing and decorative industries.
Jun 10, 2016 -
Gold Plating Services in Santa Clara CA Installs Technic ENEPIG Process
Sep 18, 2024 -
GE DS3800DMPK1E1D
Sep 18, 2024 -
HONEYWELL MU-PAOX03 51304672-100
Sep 18, 2024 -
ABB AV31 AV 31 Module
Sep 18, 2024 -
1757-SRM Redundant Module
Sep 18, 2024 -
AMTEX HSE200-120160
Sep 18, 2024 -
ABB PFEA112-20 3BSE050091R20
Sep 18, 2024 -
SIEMENS 505-6108 8-Channel Analog Input Module
Sep 18, 2024 -
INFI90 INFI 90 Analog Control Station
Sep 18, 2024 -
BENTLY NEVADA 3500/60 133811-01
Sep 18, 2024 -
ABB DP620 3BHT300016R1
Technic Releases Black Pad Resistant Electroless Nickel news release has been viewed 1175 times
