Economical Benchtop Depaneling Router
Sep 08, 2021
R100 Router with Tooling
Safely Singulate Rectangular or Round Tab Routed Panels .
Singulating low volume tab routed PCBs to strict military specifications requires the right tool for the job. Now, with the benchtop PCB depaneling router from FKN Systek, applications requiring routing rather than punching are easily taken care of. This machine is also useful as a backup to high-speed programmable routers for short runs, and for separating thick back planes which cannot be singulated by other means.
The FKN R100 Tabletop Depaneling Router is designed for manually separating PCB panels and producing uniform edges with quality comparable to in-line programmable router systems. Featuring a positioning collet with two fully adjustable guide pins on either side of the router bit, this depaneling router cleanly separates the boards along the routing channel path.
Accommodating virtually any size PCB, the FKN R100 Tabletop Depaneling Router has tooling which lets an operator match the contour of the cutting path around a PCB panel. Standard features include an adjustable spindle speed up to 35,000 RPM, adjustable router bit height, choice of 5 standard bit sizes and built- in dust extraction channel.
For more information see our home page, call or E Mail
FKN Systek
115 Pleasant Street
Millis, MA 02054
Tel. 508 376 2500 Fax 508 376 2505
E Mail: FKN@FKNSYSTEK.com
www//Fknsystek.com
Oct 11, 2023 -
Singulating Aluminum Tab Routed Panels with the N200 Punch
Oct 04, 2023 -
FKN Systek Provides Blade Resharpening for PCB Depanelizers
Sep 21, 2023 -
FKN Systek Depanelizers at Anheim Electronics Show
Sep 20, 2023 -
Singulating Pre-Scored PCB Panels up to 48"Long
Sep 21, 2022 -
Pneumatic Nibbler for singulating multiple tabs of a tab Routed PCB
Feb 17, 2022 -
Jul 01, 2020 -
Depaneling Saws for Low Stress PCB Singulation
Sep 13, 2019 -
PCB Work Holding Trays L shaped
Sep 06, 2019 -
FKN Systek, Inc. --- 3 Blade N100 Nibbler
Apr 23, 2019 -
Custom Crimp Dies for FKN C200 Pneumatic Press
5 more news from FKN Systek »
Economical Benchtop Depaneling Router news release has been viewed 878 times
