  • ESSEMTEC to Highlight EXPERT-SAFP Prototyping Station at APEX 2009
Mar 19, 2009
Essemtec, a leading manufacturer of surface mount technology production equipment, announces that it will feature EXPERT-SAFP universal prototyping station in booth 243 at the upcoming APEX 2009 exhibition and conference, scheduled to take place March 31-April 2, 2009, in Las Vegas.
Small batches and prototypes of assembled SMD boards can be mounted quickly and accurately using the Essemtec's EXPERT-SAFP semi-automatic pick-and-place system. The pick-and-place head is air suspended, and moves gently and ergonomically, allowing fast and accurate work.
When the component structure moves to fine-pitch or if a manual alignment is not possible (BGA, microBGA, flip chip), the integrated vision and placement system MPL3100 can help. Its double prisma optical system can display the component and the substrate overlay on one screen. Alignment and placement is then easy and the large zoom range of the optic enables a highly accurate result.
The EXPERT-SAFP placement system is perfectly suited for prototyping because it allows components to be picked from both reels and sticks, and from rest tape strips as well as loose components. A turning station for upside down components standard on the system.
Because fast and precise placement is also a basic requirement in small batch manufacturing, the EXPERT placement system can be connected with computer controls and works in a semi-automatic mode. Placement data can be converted directly from the CAD file or thought point by point. The Windows control software increases productivity - in some cases, it even doubles it - and ensures that the correct component is correctly aligned at the desired place without errors.
The EXPERT placement system is available as a complete prototyping station, including a dispenser and a reflow tool.
Essemtec is the only manufacturer to cover the entire production process, from Printers and/or Dispensers, to Pick-and-Place and Soldering equipment. Therefore, customers benefit from unparallel knowledge and the ability to select, from a single source, a complete process solution to meet their requirements.
Jun 10, 2024 -
May 20, 2024 -
Mar 18, 2024 -
Mar 11, 2024 -
Nov 05, 2021 -
Nov 05, 2021 -
Oct 13, 2021 -
Oct 07, 2021 -
Aug 26, 2021 -
Aug 13, 2021 -
Aug 09, 2024 -
ESSEMTEC to Highlight EXPERT-SAFP Prototyping Station at APEX 2009 news release has been viewed 675 times
