  • Everett Charles Technologies Introduces New Automotive and Industrial Catalog
Dec 12, 2011
Everett Charles Technologies (ECT) announces the release of its new Automotive and Industrial Catalog for Asia, the Americas and Europe. The new catalog features complete product descriptions and applications for ECT’s general purpose replaceable and non-replaceable probes as well as step, switch, high current/high-frequency and battery probes.
General Purpose - Replaceable Probes are designed for typical automotive board test and standard continuity test, contacting industry norm test points such as leads, vias and pads. The Threaded Probe/Receptacle is the most secure method and typically is used in wire harness testing to guarantee retention of probe in recep­tacle during test of automobile or aircraft harnesses.
General Purpose - Non-Replaceable Probes are designed for industrial applications where typical probe life meets or exceeds those of the end-use product. A non-replaceable probe is designed to be permanently fixed in the retention plate and not removed without breaking the electrical connection or damaging the retention plate.
“Step” or “Hat” Probes use a “step” to control the distance of the probe tip’s entry into a wire harness connector housing.
Switch Probes are designed primarily for “presence/electrical” test ap­plications such as detecting the absence or presence of contacts within a wire harness connector.
High Current & High-Frequency Probes are designed for powered functional testing of connectors, wire harnesses, modules and other devices drawing up to 50A.
Battery Probes typically are contained in modules where consistent, long-life, low-resistance, compliant electri­cal and mechanical connections are required.
For more information or to view the new catalog, visit www.ectinfo.com/cpg/resource/default.cfm?exec=companyinfo&dfid=3&groupid=8.
Everett Charles Technologies is a subsidiary of Dover Corporation (NYSE: DOV) a leading manufacturer of electrical test products and services, including Pogo test contacts, semiconductor test products, bare-board automatic test systems, and bare and loaded PCB test fixtures.  ECT manufacturing, service, and support facilities are ISO registered with locations throughout the United States, Europe, and Asia.  The company has been awarded numerous patents and participates actively in developing industry standards.  Corporate offices for Everett Charles Technologies are located at 700 E. Harrison Ave., Pomona, California, USA, 91767.
Dec 12, 2017 -
ECT’s Switch Probes: Cost-Efficient Solutions for Testing Electronic Assemblies
Apr 23, 2014 -
Everett Charles Technologies Brings the Latest Advances in Electrical Testing to DMEDS
Jan 14, 2014 -
ECT to Introduce High-Performance Radial Connectors at ATX/MD&M West
Jan 07, 2014 -
ECT Releases High-Performance Radial Connectors
Nov 20, 2013 -
ECT Offers ZIP® Z0 and Z1 Contacts in HyperCoreTM Base Material
Oct 11, 2013 -
ECT to Showcase Electrical Test Products and Services at Productronica
Sep 17, 2013 -
ECT Technical Expert to Discuss Breakthrough PCBA Test Probe Technologies at SMTAI 2013
Sep 12, 2013 -
ECT to Bring Compliant Connector Solutions to SMTAI 2013
Aug 12, 2013 -
New Compliant Connector Solutions from ECT at ITC 2013
Mar 29, 2013 -
ECT to Exhibit at the Del Mar Electronics & Design Show
63 more news from Everett Charles Technologies (acquired by LTX-Credence, which was acquired by Cohu) »
Aug 09, 2024 -
Everett Charles Technologies Introduces New Automotive and Industrial Catalog news release has been viewed 1205 times
