  • See ECT’s New HyperCore Base Material at the Silicone Valley Test Workshop
Aug 23, 2012
 Everett Charles Technologies’ (ECT) announces that it will highlight the new HyperCore Base Material in Booth #20 at the upcoming Silicon Valley Test Workshop, scheduled to take place Wednesday, August 29, 2012 at the Biltmore Hotel in Santa Clara, CA.
HyperCore is a proprietary base material developed for the highly scalable, fine-pitch ZIP® probe series. HyperCore Base Material requires no plating and features high hardness of 600 Knoop. It resists tip deformation and wear typically generated by cleaning cycles and high volume production. As it is non-plated, it can be repeatedly cleaned providing unprecedented probe life. Contact resistance and RF behavior is equal to gold plated BeCu. For example, the Z0-050 HyperCore yields stable 50 milliohm resistance and >40 GHz bandwidth. HyperCore also resists oxides similar to gold, yielding performance that will not waver even in the most stringent environments.
ECT also will highlight its expanded line of semiconductor products including ZIP® and Bantam® contacts. Demonstration of ZIP®’s extreme scalability and broad application solutions will include the following:
ZIP® Z1 and Z2 ― High performance production contacts that service standard and high-speed applications in .3mm, .4mm, .5mm and .8mm pitches.
ZIP® SCRUB™ ― The ZIP® SCRUB pin features a patented scrub-action. Designs for leaded, pad and BGA applications provide a self cleaning penetrating motion every compression which extends the mean time between cleaning cycles.
ZIP® KELVIN ― ECT’s ZIP® KELVIN is ideal for voltage sensitive device tests on array or peripheral devices requiring sub-1 ohm resistance measurements typical in RDSON and high-power applications.
ZIP® SUPER SHORT ― The SUPER SHORT is designed for 0.5nH low impedance, high frequency testing.
ZIP® Extended Length ― The ZIP® Extended Length lines enable quick-turn customization of travel and OAL up to 6.7mm. The Z3 line was developed for applications where contacting large devices and strip packages requires a high degree of compliance.
Z8 ―The Z8 is designed for burn-in applications. It combines the performance features of standard ZIP® architecture with a burn-in price point. The Z8 has the same form factor as the Z1 and Z2 lines so migration from lab characterization to high volume production is seamless.
The ZIP® patented 2-D design features planar contact surfaces fabricated by a unique manufacturing process, delivering maximum performance and cost advantages. The ZIP® Series is designed to meet today’s demanding test requirements and economics.
Everett Charles Technologies is a subsidiary of Dover Corporation (NYSE: DOV) a leading manufacturer of electrical test products and services, including Pogo test contacts, semiconductor test products, bare-board automatic test systems, and bare and loaded PCB test fixtures.  ECT manufacturing, service, and support facilities are ISO registered with locations throughout the United States, Europe, and Asia.  The company has been awarded numerous patents and participates actively in developing industry standards.  Corporate offices for Everett Charles Technologies are located at 700 E. Harrison Ave., Pomona, California, USA, 91767.  Additional information about ECT is available via the Internet at www.ectinfo.com.
Dec 12, 2017 -
ECT’s Switch Probes: Cost-Efficient Solutions for Testing Electronic Assemblies
Apr 23, 2014 -
Everett Charles Technologies Brings the Latest Advances in Electrical Testing to DMEDS
Jan 14, 2014 -
ECT to Introduce High-Performance Radial Connectors at ATX/MD&M West
Jan 07, 2014 -
ECT Releases High-Performance Radial Connectors
Nov 20, 2013 -
ECT Offers ZIP® Z0 and Z1 Contacts in HyperCoreTM Base Material
Oct 11, 2013 -
ECT to Showcase Electrical Test Products and Services at Productronica
Sep 17, 2013 -
ECT Technical Expert to Discuss Breakthrough PCBA Test Probe Technologies at SMTAI 2013
Sep 12, 2013 -
ECT to Bring Compliant Connector Solutions to SMTAI 2013
Aug 12, 2013 -
New Compliant Connector Solutions from ECT at ITC 2013
Mar 29, 2013 -
ECT to Exhibit at the Del Mar Electronics & Design Show
63 more news from Everett Charles Technologies (acquired by LTX-Credence, which was acquired by Cohu) »
Sep 07, 2024 -
FOXBORO FBM207B Channell Solated P0914WH
Sep 07, 2024 -
FOXBORO FBM228 P0922QS COMMUNICATION FIELDBUS MODULE
Sep 07, 2024 -
FOXBORO P0931RQ Cable
Sep 07, 2024 -
FOXBORO FBM215 CHANNEL ISOLATED 8 COMMUNICATION HART OUTPUT
Sep 07, 2024 -
FOXBORO CP40 Model
Sep 07, 2024 -
FOXBORO FBM230 P0926GU
Sep 07, 2024 -
FOXBORO P0916VC
Sep 07, 2024 -
FOXBORO AD916AG
Sep 07, 2024 -
FOXBORO P0904BS P0904BS-0E
Sep 07, 2024 -
FOXBORO PO177VS
See ECT’s New HyperCore Base Material at the Silicone Valley Test Workshop news release has been viewed 995 times
Fluid Dispensing Aerospace
