atg/LM to Exhibit A5-A Probe System With Automation at APEX 2008
Mar 19, 2008
atg Luther & Maelzer GmbH announces that it will display the A5-A Probe System with Automation with Everett Charles Technologies (ECT) in booth 1383 at the upcoming APEX 2008 conference and exhibition, scheduled to take place April 1-3, 2008, in Las Vegas.
The A5-A Probe System has been developed in direct response to market needs for a fully functional and affordable automated test platform for the small manufacturing facility. Taking proven atg/LM technology, the A5-A Probe System has been fully automated to meet the needs of companies with as little as one production line.
Small manufacturing facilities typically produce low volume batches or prototypes, which results in a high level of product changeover. To eliminate the need for long and complicated setup and adjustment of each PCB, the A5-A Probe System incorporates a new generation of automation to accommodate different PCB types and sizes within a short period of time. To speed this process a flexible, stress free loading and uploading system has been fully automated, with a sensitive handling function, for different PCB types. By automating this function the operator is free to perform other duties during their shift, or to set up the test process to be carried out overnight, simulating a third shift. Incorporating four high resolution CCD cameras for optical scanning, the board handling unit automatically separates �good boards� and �bad boards� in a cycle time of less than fifteen seconds, with the added option of an automated marking system.
The A5-A Probe System can accommodate a minimum 100 mm x 72 mm (4.0� x 2.8�) and maximum 610 mm x 460 mm (24�x18�) board size. The minimum thickness is 0.8 mm down to a board size of 320 mm x 250 mm (12� x 10�) and 0.6 mm lower than 320 mm x 250 mm (12� x 10�), with a maximum of 4mm (0.15�). atg/LM�s new A5-A Probe System ensures that even small manufacturing facilities can rely on the quality and reliability of the products tested, making automated test affordable for all.
Dec 12, 2017 -
ECT’s Switch Probes: Cost-Efficient Solutions for Testing Electronic Assemblies
Apr 23, 2014 -
Everett Charles Technologies Brings the Latest Advances in Electrical Testing to DMEDS
Jan 14, 2014 -
ECT to Introduce High-Performance Radial Connectors at ATX/MD&M West
Jan 07, 2014 -
ECT Releases High-Performance Radial Connectors
Nov 20, 2013 -
ECT Offers ZIP® Z0 and Z1 Contacts in HyperCoreTM Base Material
Oct 11, 2013 -
ECT to Showcase Electrical Test Products and Services at Productronica
Sep 17, 2013 -
ECT Technical Expert to Discuss Breakthrough PCBA Test Probe Technologies at SMTAI 2013
Sep 12, 2013 -
ECT to Bring Compliant Connector Solutions to SMTAI 2013
Aug 12, 2013 -
New Compliant Connector Solutions from ECT at ITC 2013
Mar 29, 2013 -
ECT to Exhibit at the Del Mar Electronics & Design Show
63 more news from Everett Charles Technologies (acquired by LTX-Credence, which was acquired by Cohu) »
Sep 07, 2024 -
FOXBORO FBM207B Channell Solated P0914WH
Sep 07, 2024 -
FOXBORO FBM228 P0922QS COMMUNICATION FIELDBUS MODULE
Sep 07, 2024 -
FOXBORO P0931RQ Cable
Sep 07, 2024 -
FOXBORO FBM215 CHANNEL ISOLATED 8 COMMUNICATION HART OUTPUT
Sep 07, 2024 -
FOXBORO CP40 Model
Sep 07, 2024 -
FOXBORO FBM230 P0926GU
Sep 07, 2024 -
FOXBORO P0916VC
Sep 07, 2024 -
FOXBORO AD916AG
Sep 07, 2024 -
FOXBORO P0904BS P0904BS-0E
Sep 07, 2024 -
FOXBORO PO177VS
atg/LM to Exhibit A5-A Probe System With Automation at APEX 2008 news release has been viewed 1092 times
