Schleuniger Introduces CableCoiler 1450 Single Pan Coiling System
Jan 17, 2018
The CableCoiler 1450 is a single pan coiling system that is used to coil wire, cable, or tubing. It features a rotary design with moveable pins to adjust for different coiling diameters. Another unique feature of this design is the easy unloading scheme, using retracting pins and an automatic safety cover lift. The unique design of the coiling system ensures safe operation by performing all of the rotating movements in a downward facing position with a closed and monitored safety shield.
The machine is very versatile and can function in one of two different operating modes:
  • Coil only – for efficient offline coiling of precut materials.
  • Auto coil – as an integrated post processing accessory for use with cut & strip machines.
The CableCoiler 1450 offers programmable parameters, including cable diameter and length, inner/outer diameter of cable coil and configuration parameters such as distance after cutting, speed synchronization adjustment, etc. All programmed parameters can be saved in jobs for easy and fast recall via the user interface or with a barcode scanner. Jobs can also be imported and exported between coilers with a USB stick.
The new CableCoiler 1450 offers fully synchronized, precise wire and cable coiling and is compatible with the latest generations of Schleuniger cut and strip machines.
More information about this new product can be found at www.schleuniger-na.com. Should you have any questions, please e-mail sales@schleuniger.com or call (603) 668-8117.
About Schleuniger
The Schleuniger Group in Thun is a globally active technology company and a leading supplier to the wire processing industry. With its wholly-owned and independently managed company, DiIT, Schleuniger is in addition a leading player in digitalization and industrial IoT.
Most of the Schleuniger Group's customers are suppliers to the automotive, entertainment and information industries as well as for the communications sector. Schleuniger’s products are used wherever precise connections and highest productivity are required. The company has development and production locations in Switzerland, Germany and China. Due to its sales and service companies in North America, Europe and Asia and more than 40 distribution partners worldwide, Schleuniger is always close to its customers.
The Schleuniger Group represents the wire processing business segment of the publicly listed Metall Zug Group and has more than 700 employees and 30 apprentices worldwide.
Apr 03, 2020 -
CrimpCenter 64 SP - Produce Faster, More Precisely, More Cost Effectively
Feb 14, 2020 -
Schleuniger, Inc. to Exhibit Wire Processing Equipment at the 2020 Del Mar Electronics and Manufacturing Show
Nov 12, 2019 -
Schleuniger Press Release - BHC Cable Assemblies Relies on Schleuniger Precision and Durability
Sep 12, 2019 -
Schleuniger, Inc. to Exhibit Latest Wire Processing Innovations at M-Expo
Sep 12, 2019 -
Schleuniger, Inc. to Exhibit Latest Wire Processing Advances at ATX Minneapolis
Sep 12, 2019 -
Schleuniger, Inc. to Exhibit Latest Wire Processing Advances at The ASSEMBLY Show
Apr 03, 2018 -
Schleuniger, Inc. to Debut New Wire Processing Equipment at Electrical Wire Processing Technology Expo
Nov 27, 2017 -
Acquisition of majority stake in adaptronic Prüftechnik GmbH
Jun 22, 2017 -
Schleuniger, Inc. Receives 2017 Best of Manchester Award
Feb 08, 2017 -
Schleuniger Acquires Leading Software Supplier
14 more news from Schleuniger, Inc. »
Jul 16, 2024 -
Jul 16, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Schleuniger Introduces CableCoiler 1450 Single Pan Coiling System news release has been viewed 1093 times
