  • Special Function and Performance for LED Board Production  Released LED Mounter JX-300LED
Oct 04, 2013
Special Function and Performance for LED Board Production Released LED Mounter JX-300LED April 1st, 2013, JUKI released LED Mounter JX-300LED, a specialized model with efficient function and performance for LED board production. Today the demand of LED, used for lighting device or LCD display for television and computer, is significantly increasing for its energy saving and long-life characteristic. JUKI already has Flexible Compact Mounter JX-100LED for LED productions, but this new JX-300LED has enlarged its PCB size capacity and improved the placement speed.
As a standard feature, JX-300LED is now capable for production of maximum 1200 mm PCB, to meet the high demand sized LED lighting device and middle/large sized LCD backlight. As an option, it will be able to produce maximum 1500mm sized PCB, the largest capability in the industry. Additionally, high accurate placement of light diffuser lens, a production technology recently being widely used for LCD backlight production, is now possible by using our original laser sensor to identify the boss* on the lens to determine the correct direction. Through the improvements of PCB conveyance, the placement speed also has been significantly advanced.
Due to its improved board size capability and high-speed operation, JX-300LED is acquiring a great reputation in the growing market of LED board production and expanding its sales gradually.*boss: protuberance on the bottom of the light diffuser lens to ensure the correct position of SMD.
Features
1) Improved Placement Speed
The manufacturing of long sized PCB requires multiple clamps. The conveyor transportation time is cut by changing the PCB stopper method from sensor control to mechanical stopper, and by modifying the PCB holding method to face-side clamp. These changes improved the placement speed significantly.
Mid-size LED components can be placed in 19,300 CPH. (with 12mm Tape Feeder, 6 nozzle alternate placement by 3 nozzle simultaneous pick x 2 times)
2) LED Placement
The machine is capable of PCB size 610mm x 360mm by one time clamp, 1200mm x 360mm by two times clamp, and 1500mm x 360mm by three times clamp.
When manufacturing long board with several clamps, the machine is able to identify the solders printed on the electrodes as BOC mark. (option)
Efficient component supply of tray components (Ex. light diffuser lens) is possible by using Tray Holder or Matrix Tray Server. (option)
Realized space saving machine size, 1920mm x 1393mm, the highest class for mounter with the capablility of 1200mm x 360mm PCB production.
3) Easy Operation
Equipped with GUI (Graphical User Interface), which makes the operation easy for beginners. Operation by touch panel, without keyboard, is also available. (option)
Since the time for preparing data is greatly shortened by the components laser recognition technology, vertical startup of production is possible.
4) Excellent Cost Performance
Featured power consuption saving design; apparent power 3.0 kVA.
Nozzles, tape feeders, and production technology data are compatible with other JUKI models, so you can utilize your existing properties.
Mar 26, 2024 -
Juki Receives 2024 NPI Award for ISM 3600 Front AMR (FAMR) System
Mar 18, 2024 -
Meet Juki's New LX-8 & 2nd Gen Automated Material Handling System at APEX 2024
Sep 11, 2023 -
Juki Automation Systems Is Setting New Standards in Efficiency at SMTA International 2023
Mar 06, 2023 -
Juki Automation Systems Promotes Greg Lefebvre to National Sales Manager
Dec 21, 2022 -
Juki Automation Systems to Launch New LX-8 High-Speed, Flexible Mounter at APEX 2023
Oct 06, 2022 -
Juki Automation Systems Speeds Up Assembly in Booth #731 at SMTAI
Sep 26, 2022 -
Juki Wins 2022 Mexico Technology Award for Game-Changing Automated Component Storage
Aug 26, 2022 -
Juki Automation Systems to Highlight Autonomous Material Handling & JM-50 at SMTA Guadalajara
May 05, 2022 -
BayaTronics Opens New Contract Manufacturing Facility with Complete Juki Line
Feb 25, 2022 -
Juki wins two NPI Awards & celebrates 60th industry award
287 more news from Juki Automation Systems »
May 23, 2024 -
May 21, 2024 -
May 21, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
Special Function and Performance for LED Board Production  Released LED Mounter JX-300LED news release has been viewed 573 times
Manufacturing Software
