  • GPD Global to Exhibit PCD 'H' Series at Assembly & Automation Technology Expo 2011
Aug 22, 2011
PCD Dispensing with a Syringe Mixing System keeps fluids such as LED encapsulants with phosphor evenly mixed before they are dispensed
GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix and R&D production will debut its Positive Cavity Displacement (PCD) 'H' Series high-resolution pumps in Booth #1849 at the upcoming Assembly & Automation Technology Expo, scheduled to take place September 20-22, 2011 at McCormick Place North in Chicago, IL.
GPD also will display the PCD Dispensing with a Syringe Mixing System that keeps fluids such as LED encapsulants with phosphor evenly mixed before they are dispensed.
May 21, 2024 -
Apr 06, 2024 -
Aug 01, 2023 -
Dec 17, 2019 -
Jan 09, 2019 -
Oct 08, 2018 -
Sep 06, 2018 -
Feb 12, 2018 -
Nov 07, 2017 -
Oct 02, 2017 -
Sep 14, 2024 -
1769-L18ERM-BB1B MOTION Processors
Sep 14, 2024 -
ABB 1KHL016009R0001 NSK5G4AK
Sep 14, 2024 -
SIEMENS 7UT5131-5CB01-1BA0/KL
Sep 14, 2024 -
EPRO PR6424/104-141 CON041
Sep 14, 2024 -
SIEMENS 6DS1122-8AA
Sep 14, 2024 -
NISSEI BS1-N018
Sep 14, 2024 -
ABB DSMC110 57330001-N
Sep 14, 2024 -
BENTLY NEVADA 330104-00-24-10-02-00
Sep 14, 2024 -
LEUZE IFRK 93/4-100 L.2
Sep 14, 2024 -
BENTLY NEVADA 133396-01
GPD Global to Exhibit PCD 'H' Series at Assembly & Automation Technology Expo 2011 news release has been viewed 1188 times
Solder Paste Dispensing
