GPD Global to Showcase PCD 'H' Series at IMAPS - Long Beach 2011
Sep 12, 2011
Positive Cavity Displacement (PCD) ‘H’ Series high-resolution pump
GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix and R&D production, will showcase its Positive Cavity Displacement (PCD) 'H' Series high-resolution pumps in Booth #439 at the upcoming IMAPS 44th International Symposium on Microelectronics, scheduled to take place October 11-13, 2011 at the Long Beach Convention Center in Long Beach, CA.
GPD also will demonstrate the PCD and MicroDot technologies on its MAX Series platform. MAX Series dispensing systems offer high accuracy, precision dispensing over a wide range of applications. The MAX Series platforms are ideal for die attach, underfill, MEMS, micro-volume conductive adhesive and paste applications. Max Series equipped with Micro-volume technology enables dispensing for 0201 components as well as die attach adhesives. Further expanding the Max Series capabilities with the continuously volumetric PCD dispense pump yields outstanding results with underfills, encapsulation and LED applications.
May 21, 2024 -
Apr 06, 2024 -
Aug 01, 2023 -
Dec 17, 2019 -
Jan 09, 2019 -
Oct 08, 2018 -
Sep 06, 2018 -
Feb 12, 2018 -
Nov 07, 2017 -
Oct 02, 2017 -
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
GPD Global to Showcase PCD 'H' Series at IMAPS - Long Beach 2011 news release has been viewed 1104 times
