  • GPD Global's PCD Dispensing on Its MAX Series Platform Recognized with Two 2011 Global Technology Awards
Nov 20, 2011
GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix and R&D production, announces that it has been awarded two Global Technology Awards in the categories of Adhesives/Coatings/Encapsulants and Dispensing Equipment for its PCD Dispensing on the MAX Series Platform. The awards were presented to the company during a Tuesday, November 15, 2011 ceremony that took place at the New Munich Trade Fair Centre in Munich, Germany during Productronica 2011.
When coupled with the MAX II Dispense platform and UltiPath optimization software for the BGA underfill process, the result is increased throughput by reducing idle time from optimizing the dispense paths associated with multiple dispense pass products. The MAX Series platforms are ideal for die attach, underfill, MEMS, micro-volume conductive adhesive and paste applications. Max Series equipped with Micro-volume technology enables dispensing for 0201 components as well as die attach adhesives.  Further expanding the MAX Series capabilities with the continuously volumetric PCD dispense pump yields outstanding results with underfills, encapsulation and LED applications.
Premiering in 2005, the Global Technology Awards program is an annual celebration of product excellence in electronics surface mount assembly. Premier products based on the finest examples of creative advancement in technology are chosen by a distinguished panel of industry experts.
May 21, 2024 -
Apr 06, 2024 -
Aug 01, 2023 -
Dec 17, 2019 -
Jan 09, 2019 -
Oct 08, 2018 -
Sep 06, 2018 -
Feb 12, 2018 -
Nov 07, 2017 -
Oct 02, 2017 -
Jun 28, 2024 -
Jun 26, 2024 -
Jun 25, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
GPD Global's PCD Dispensing on Its MAX Series Platform Recognized with Two 2011 Global Technology Awards news release has been viewed 1136 times
