GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix and R&D production, announces the global release of its PCD4 Dispense Pump after its successful release and testing in the North American market.
The PCD4 dispense pump was introduced to the North American market in June 2010. PCD4 also is now available in the Asia/Pacific region and Europe. GPD Global is expanding to support the worldwide market for individual pump and controller sales.
GPD’s PCD Dispensing provides next-generation volumetric dispensing and is compatible with materials used in electronics assembly such as LED encapsulants, underfills, oils, silicones and UV curable fluids, as well as many other low-viscosity liquids outside of the electronics industry. PCD Technology is designed for GPD Global platforms and may be used with other robots or tabletop operations with an easy-to-use tabletop controller.
For more information about PCD pump technology, visit www.gpd-global.com.
