  • Automatic Dispense Repeatability for All Fluid Types GPD Global to Debut FPC at SMTA International
Oct 08, 2013
GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix and R&D production, will debut its patent-pending FPC (Fluid Pressure Control) Dispensing System at SMTA International. FPC offers a breakthrough in uniform fluid dispensing by ensuring a consistent supply of fluid to the pump regardless of reservoir size or fluid level.
Dispense pumps, in general, are very repeatable devices with high accuracy control systems and precision machining.  However, when the consistency of fluid entering the pump varies, the output also varies.  Operators routinely make changes to the fluid pressure or pump parameters to compensate for fluid variations that can come from the syringe fluid level.  FPC eliminates this operator interaction automatically and ensures that the feed pressure into the pump is constant. By maintaining a constant pressure of fluid into the pump that is independent of reservoir pressure, FPC ensures the dispense pump has a sufficient supply of fluid resulting in uniform and repeatable fluid displacement.
FPC is an upgrade to installed GPD MAX and DS Series dispense systems and can be added to new system configurations. For bench-top systems or others looking to improve dispense results, FPC is available as a stand-alone controller and hardware set. It is compatible with all types of dispense pumps, including auger, needle, pinch tube and even jetting pumps. Just set the feed pressure and let FPC maintain a constant input to the dispense pump.
GPD will showcase FPC for the first time in Booth #215 at the upcoming SMTA International Exhibition, scheduled to take place October 15-16, 2013 at the Fort Worth Convention Center in Texas. Please contact a local GPD Global representative regarding this fresh approach to repeatable fluid dispensing.
May 21, 2024 -
Apr 06, 2024 -
Aug 01, 2023 -
Dec 17, 2019 -
Jan 09, 2019 -
Oct 08, 2018 -
Sep 06, 2018 -
Feb 12, 2018 -
Nov 07, 2017 -
Oct 02, 2017 -
Automatic Dispense Repeatability for All Fluid Types GPD Global to Debut FPC at SMTA International news release has been viewed 1156 times
