GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix, and R&D production will exhibit in Booth 2933 at the upcoming IPC APEX EXPO 2017 scheduled to take place February14-16, San Diego Convention Center. GPD Global will officially launch its new, fully automated dispense platform, Hyperion, and a new, low cost conformal coating system.
See NEW Hyperion dispensing system in action at booth 2933: a fully automated dispense platform that incorporates the latest technology from GPD Global in a compact footprint. Equipped with linear motor drive, smart pump technology, full touch screen interface, vision centric system operation and more, this is a dispense system not to be missed.
SimpleCoat, a NEW low cost, simple, inline Conformal Coating System with full featured programming software makes the conformal coating processes quick and easy to set up. This conformal coating machine incorporates a spray and dispense pump, external reservoir fluid feeding, nozzle park area with solvent, fume extraction, and chain conveyor. Visit Booth 2933 for more information about this low cost Conformal Coating System.
High Precision Dispensing System (MAX Series) will run live demonstration of Solder Paste 01005/0201 dispensing. The system will be configured with the new 062 ultra-fine Precision Auger Pump. This extends the previously impossible limits of small volume solder paste dispensing, making 01005 dispensing possible. The MAX Series dispensing system is capable of a wide variety of dispense applications including Low-to-High Volume, Solder Paste, Conductive Adhesive, Underfill, Surface Mount Adhesive, etc.
GPD Global will also exhibit a full range of Latest Dispense Technologies for integration or retrofit into your existing platforms. Pumps on display include the versatile Precision Auger Pump which can dispense low-to-high volumes with a simple change-over. Interfacing the pump with your system is easy with the enhanced Servo Pump Controller.
A Jetting process can now be integrated with your dispense system by interfacing the NCM5000 Jetting Pump with bench top controller. This jetting pump is compatible with a wide range of liquids, from UV encapsulants to underfills and SMT adhesives. To round out the pumps line up, the Volumetric Pump Series (PCD) will be on display. This continuously volumetric pump dispenses low-to-high viscosity greases with outstanding repeatability over the full range of fluid pot life.
Along with our full line of dispense equipment and the new conformal coating system, component preparation product lines will also be on display. Axial Lead Forming System (CF-8) meets exacting military standards for axial taped or bulk components while eliminating component body stress. The CF8 delivers consistent results for components being formed either vertically or horizontally at a rate of up to 25,000 parts per hour. Radial Lead Forming System (CF-9) forms and cuts 2- and 3-leaded taped components such as TO-92s (live demo at booth 2933), capacitors, transistors, and LEDs. This system is designed to precisely and repeatedly form standard, as well as special formed lead configurations, with consistent ease at a rate of 25,000 parts per hour. Radial Lead Forming System for Loose/Bulk (CF-10) forms and cuts 2, 3, 4, 5 and 7-leaded loose/bulk components such as TO-220s (live demo at booth 2933), capacitors with uniform body shape, and more. This system precisely and repeatedly forms standard, as well as special formed lead configurations, at a rate of 5,000 parts per hour with its variable speed motor.
Stop by Booth 2933. Experts are there to discuss your production needs. Whether your project requires a pump for retrofitting or a fully automated dispense system, coating, or component preparation, we have a solution for you.
