Sep 07, 2017
SimpleCoat is ideal for selective conformal coating and dispensing applications that require a high level of accuracy and repeatability. It is an ideal solution for medium and low volume.
Conformal Coating Machine with excellent repeatability for under $40,000!!!
GPD Global, a manufacturer of high quality precision fluid dispensing systems, conformal coating, and component prep systems, will  exhibit at the upcoming SMTA International 2017. The Expo is scheduled to take place September 19-20 at the Donald E. Stephens Convention Center in Rosemont, Illinois.
At booth# 216, on display is an automated Conformal Coating Machine with excellent repeatability for under $40,000. SimpleCoat is a NEW low cost, inline, simple Conformal Coating System with full featured programming making the conformal coating processes quick and easy to set up. This Conformal Coating System incorporates teach from .JPG programming, SMEMA communication with chain conveyor for inline process, spray and needle valve, an exhaust port with flow sensor, external reservoir fluid feeding, and nozzle park area with solvent baths.
GPD Global’s line of Fluid Dispensing pumps with the latest dispense technologies for integration or retrofit will also be exhibited. Whether your process requires low or high viscosity fluids, thick pastes, or abrasive media, there is a dispense pump to meet your requirements. The versatile Precision Auger Pump is excellent for dispensing pastes down to 150µm; the carbide wetted parts are great for abrasive fluids. High speed NCM5000 Jetting Pump dispenses small droplets from 2-4 mm above the surface. Volumetric Pump Series (PCD) dispenses low-to-high viscosity greases with outstanding repeatability.
Furthermore, GPD Global manufactures a selection of fully automated fluid dispensing systems to meet high production demands and the versatility of development.
Stop by booth 216. Experts are there to discuss your production needs. Whether your project requires a pump for retrofitting or a fully automated dispense system, coating or component preparation, we have a solution for you.
May 21, 2024 -
Apr 06, 2024 -
Aug 01, 2023 -
Dec 17, 2019 -
Jan 09, 2019 -
Oct 08, 2018 -
Sep 06, 2018 -
Feb 12, 2018 -
Nov 07, 2017 -
Oct 02, 2017 -
Oct 15, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Conformal Coating & the Latest Dispense Technology at SMTAI news release has been viewed 1812 times
