Nov 07, 2017
SimpleCoat is ideal for selective conformal coating and dispensing applications that require a high level of accuracy and repeatability. It is an ideal solution for medium and low volume.
Alternative to the standard needle valve. Volumetric dispense technology enhances damming, masking, and fine coating applications. An adjustable flow rate allows for a finely tuned process.
GPD Global, manufacturer of high quality precision fluid dispensing systems, conformal coating and component prep systems, offers a cost-effective, automated Conformal Coating System (SimpleCoat) with excellent repeatability for just under $40,000!!!
SimpleCoat is a NEW low cost, inline, simple Conformal Coating System with full featured programming making the conformal coating processes quick and easy to set up. It is ideal for selective conformal coating and dispensing applications that require a high level of accuracy & repeatability.
This coating machine is equipped with a robust 3-axis motion platform that, in the base configuration, includes a spray valve and a needle valve. An optional volumetric pump may be used in place of the needle valve.
SimpleCoat works with a customer-supplied laptop computer.  Programming of this conformal coating system is easy and can be done either by manually teaching a program or by using a JPG image. All dispense and motion parameters can be easily altered with the easy-to-use interface. Various shapes, patterns, and areas can also be programmed.
Standard Features of the SimpleCoat Conformal Coating System base model:
  • Reliable XYZ Motion System
  • Inline Operation with SMEMA Communication
  • Spray and Needle Valve
  • Purge and Solvent Cups
  • Stainless Steel Surfaces
  • Bottom Side Fume Extraction with Exhaust Flow Sensor
  • Two 300 ml Cartridges for Fluid Feeding
  • Internal Black Light for Coating Inspection
  • Keyed Maintenance Mode
  • Light Tower
You can also enhance the Conformal Coating process with add-on options:
  • Low Level Material Sensor.
  • Large Volume Reservoir
  • Stand-alone Configuration
  • Volumetric Pump
  • Multiple Reservoirs
May 21, 2024 -
Apr 06, 2024 -
Aug 01, 2023 -
Dec 17, 2019 -
Jan 09, 2019 -
Oct 08, 2018 -
Sep 06, 2018 -
Feb 12, 2018 -
Oct 02, 2017 -
Sep 07, 2017 -
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Conformal Coating System For Under $40,000!!! news release has been viewed 1987 times
