Live demos at IPC APEX Expo 2024 – Booth 1504 – April 9-11, 2024, Anaheim, CA
GRAND JUNCTION, CO USA -- April 2024 -- GPD Global – manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix, and R&D production – will exhibit in Booth 1504 at IPC APEX EXPO 2024 on April 9-11 in the Anaheim Convention Center, CA.
Stop by booth 1504 to see the latest dispensing systems and solutions from GPD Global. Experts will be there to discuss your dispensing needs, such as underfill, thermal interface material, solder paste, glob top, glue dispensing, staking, conformal coating and more. Whether your project requires a dispensing valve for retrofitting or an automatic dispense system, conformal coating systems, or component preparation, we have a solution for you.
LIVE DEMOS – Fluid Dispensing Pumps
A full range of Dispense Technologies will be on display:
- Jetting Valves – For underfill, solder paste, and other high throughput applications.
- Volumetric Valve – Volumetric dispense pump with total fluid control, Progressive Cavity Displacement Technology, great for viscosities 0-65,000 cps.
- Auger Valve – Micro Volume Dispensing.
- Time Pressure Dispensing with Fluid Pressure Control (FPC) – enhance manual process for better dispensing results.
LIVE DEMOS – Thru-Hole Equipment
Component Preparation for Through-Hole Applications
- Axial Lead Forming System (CF-8): meets exacting military standards for axial taped or bulk components while eliminating component body stress. Consistent results for components being formed either vertically or horizontally.
- Radial Lead Forming System (CF-9): forms and cuts 2- and 3-leaded taped components, capacitors, transistors, and LEDs. This system is designed to precisely and repeatedly form standard and custom configurations, with consistent ease.
GPD Global is an equipment manufacturer of high quality, precision, automated fluid dispensing, conformal coating, & component-prep systems. International, state-of-the-art equipment supplier for PCB assembly and semiconductor industries. Design and manufacture wide variety of Automatic Fluid Dispensing & Conformal Coating Systems. We also manufacture SMT Cover Tape Peel Tester and Component Prep equipment for Thru-Hole applications.
