GRAND JUNCTION, CO USA – January 2026 -- GPD Global, a leading manufacturer of precision fluid dispensing systems, is excited to announce its introduction of the All-New UltraMAX™ fluid dispensing system in the APEX EXPO 2026. Join us at Booth 2732 from March 17-19 at the Anaheim Convention Center, CA, to explore our cutting-edge dispensing solutions.
UltraMAX™: The Next-Generation Standard in Precision Fluid Dispensing
UltraMAX™ is the next-generation fluid dispensing system built for advanced manufacturing—delivering precise motion control, broad material compatibility, and an intuitive new software experience for operators and process engineers alike.
Key Capabilities:
- 1-micron resolution encoders for ultra-accurate motion and placement
- Enhanced pressure stability controls for consistent deposit quality
- Expert-driven pump configurations optimized for a wide range of applications
- Reliable performance across 1 cP to 1,000,000 cP materials
- Compatible with UV curables, solder pastes, conductive epoxies, and complex chemistries
High-Speed Innovation:
- Launching with a high-speed solder paste jetting dispense pump
- Engineered for throughput without sacrificing accuracy or repeatability
Modern Software Experience
- Powered by Windows 11
- CAD import for efficient programming
- Component library for faster job setup
- On-screen process visualization for real-time insight and control
In addition to the UltraMAX™ reveal, our experts will be on-site to discuss your specific dispensing needs – whether for underfill, thermal interface materials, solder paste, glob top, glue dispensing, staking, or conformal coating. From retrofitting dispensing valves to fully automatic systems and component preparation, we have the right solution for you.
DEMOS – Fluid Dispensing Technologies.
We will also be showcasing our full range of trusted dispensing technologies:
Jetting Valves
High-speed precision for underfill, solder paste, and high-throughput applications.
Volumetric Valves
Progressive Cavity Displacement (PCD) Technology offering total fluid control, ideal for viscosities from 0 to 65,000 cps.
Auger Valves
Perfect for micro-volume dispensing requirements.
Time Pressure Dispensing
Enhanced with Fluid Pressure Control (FPC) for superior manual process results.
DEMOS – Thru-Hole Equipment
Axial Lead Forming System (CF-8)
Meets exacting military standards, eliminating component body stress for axial taped or bulk components.
Radial Lead Forming System (CF-9)
Precisely forms and cuts 2- and 3-leaded taped components, capacitors, transistors, and LEDs.
Don’t miss the chance to see the future of dispensing with the UltraMAX™ fluid dispensing system and our complete lineup of manufacturing solutions. We look forward to seeing you in Anaheim!
We look forward to welcoming you to Booth 2732 at APEX EXPO 2026! Don’t miss this opportunity to see our innovative solutions in action and discuss your specific requirements with our knowledgeable team.
GPD Global is an equipment manufacturer of high quality, precision, automated fluid dispensing, conformal coating, & component-prep systems. International, state-of-the-art equipment supplier for PCB assembly and semiconductor industries. Design and manufacture wide variety of Automatic Fluid Dispensing & Conformal Coating Systems. We also manufacture SMT Cover Tape Peel Tester and Component Prep equipment for Thru-Hole applications
