GPD Global to Focus on PCD Dispensing at ATX West 2011
Jan 12, 2011
GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix and R&D production, will highlight its Positive Cavity Displacement (PCD) Dispensing in Booth #6111 at the upcoming Automation and Technology West Expo (ATX), scheduled to take place February 8-10, 2011 at the Anaheim Convention Center in Anaheim, CA.
GPD’s PCD Dispensing provides next-generation volumetric dispensing and is compatible with materials used in electronics assembly such as epoxies, thermal greases, underfills, oils, silicones and UV encapsulants, as well as materials outside of the electronics industry.
Viscous fluids are delivered to the substrate via luer nozzles, and performance excels when using GPD Global ‘S’ Taper tips. The metering technique is not affected by variations in temperature or reservoir pressure, thereby improving day-to-day and start-to-finish process results. GPD’s enhanced flow rate luer dispense tips offer higher flow rates than standard luer nozzles with lower pressure build-up.
In addition to PCD Dispensing, GPD will highlight its MAX Series dispensing systems for a variety of dispensing applications as well as an automated fluid inspection system for verifying the presence, absence, continuity (line or area fills) and size of dispensed fluid.
May 21, 2024 -
Apr 06, 2024 -
Aug 01, 2023 -
Dec 17, 2019 -
Jan 09, 2019 -
Oct 08, 2018 -
Sep 06, 2018 -
Feb 12, 2018 -
Nov 07, 2017 -
Oct 02, 2017 -
Aug 09, 2024 -
GPD Global to Focus on PCD Dispensing at ATX West 2011 news release has been viewed 908 times
