  • GPD Global to Promote PCD Dispensing at the SMTA Dallas Expo & Tech Forum
Feb 04, 2011
GPD Global PCD showing Total Fluid Control (TFC) with water.
GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix and R&D production will highlight its Positive Cavity Displacement (PCD) Dispensing at the upcoming SMTA Dallas Expo & Tech Forum, scheduled to take place Tuesday, March 1, 2011 at the Richardson Civic Center in Richardson, TX.
GPD’s PCD Dispensing provides next-generation volumetric dispensing and is compatible with materials used in electronics assembly such as epoxies, thermal greases, underfills, oils, silicones and UV encapsulants, as well as materials outside of the electronics industry.
In addition to the PCD Dispensing, GPD will highlight its MAX Series dispensing systems for a variety of dispensing applications and an automated fluid inspection system for verifying the presence, absence, continuity (line or area fills) and size of dispensed fluid on a PCD.
May 21, 2024 -
Apr 06, 2024 -
Aug 01, 2023 -
Dec 17, 2019 -
Jan 09, 2019 -
Oct 08, 2018 -
Sep 06, 2018 -
Feb 12, 2018 -
Nov 07, 2017 -
Oct 02, 2017 -
Sep 14, 2024 -
How to Find the Best Reflow Oven for SMT in Your Industry
Sep 14, 2024 -
1769-L18ERM-BB1B MOTION Processors
Sep 14, 2024 -
ABB 1KHL016009R0001 NSK5G4AK
Sep 14, 2024 -
SIEMENS 7UT5131-5CB01-1BA0/KL
Sep 14, 2024 -
EPRO PR6424/104-141 CON041
Sep 14, 2024 -
SIEMENS 6DS1122-8AA
Sep 14, 2024 -
NISSEI BS1-N018
Sep 14, 2024 -
ABB DSMC110 57330001-N
Sep 14, 2024 -
BENTLY NEVADA 330104-00-24-10-02-00
Sep 14, 2024 -
LEUZE IFRK 93/4-100 L.2
GPD Global to Promote PCD Dispensing at the SMTA Dallas Expo & Tech Forum news release has been viewed 1125 times
