See GPD Global's PCD Technology at IMAPS Device Packaging 2011
Feb 17, 2011
GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix and R&D production will highlight its Positive Cavity Displacement (PCD) Dispensing in Booth #27 at the upcoming IMAPS Device Packaging conference and exhibition, scheduled to take place March 8-9, 2011 at the Radisson Fort McDowell Resort and Casino in Scottsdale, AZ.
In addition to the PCD Dispensing, GPD also will highlight its MAX Series dispensing systems for a wide variety of dispensing applications and automated fluid inspection system for verifying the presence, absence, continuity (line or area fills) and size of dispensed fluid on a PCD.
May 21, 2024 -
Apr 06, 2024 -
Aug 01, 2023 -
Dec 17, 2019 -
Jan 09, 2019 -
Oct 08, 2018 -
Sep 06, 2018 -
Feb 12, 2018 -
Nov 07, 2017 -
Oct 02, 2017 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
May 30, 2024 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 27, 2024 -
