NEW RF CENTER PROBE TEST SOCKET FOR DEVICES
Sep 29, 2004
From Aries Electronics
Aries Electronics, an international manufacturer of standard, programmed and custom interconnection products, now offers a new high frequency test socket for devices from 28 to 55 mm2 wide. The new socket is ideal for manual testing of devices with pitches down to 0.50 mm, in applications with speeds from 1 GHz to over 10 GHz, such as CSP, MicroBGA, DSP, LGA, SRAM, DRAM, and Flash devices.
The new RF socket provides minimal signal loss for higher bandwidth capability via a signal path of only .077� (1.95 mm). The 4-point spring probe crown on the new socket ensures �scrub� on solder ball oxides for reliable contact mating, and the pointed probe works with LGAs, MLFs and other socket types. Single point probes are available for small land area contact pads.
The socket can be easily mounted to and removed from the test board, due to solderless, pressure-mount compression spring probes accurately located by two molded plastic alignment pins and secured with four stainless steel screws. These gold over nickel compression spring probes leave very small witness marks on the bottom of the device solder balls. In addition, the socket�s small overall size provides the maximum allowable space for load board components and connectors.
Estimated contact life is over 500,000 cycles and contact self-inductance is 0.51 nH. Contact forces of the new center probe sockets are 9 g to 12 g per contact for 0.50 mm to 0.75 mm pitches, and 17 g to 20 g per contact for 0.80 mm pitches and larger. Operating temperature is -55�C to 150�C (-67�F to 302�F).
The compression spring probes are heat-treated beryllium copper alloy, plated with
30 �� min. (0.75 �m) gold per Mil-G-45204 over 30 �� min. (0.75 �m) nickel per QQ-N-290. The socket�s molded components are UL94V-0 PEEK and/or Ultem. All hardware is stainless steel.
As with all Aries sockets, the new RF test socket is available in custom materials, platings, sizes and configurations to suit specific customer applications.
Pricing for a molded 415-lead RF Center Probe socket for 2.4 GHz applications starts at $1,122 each for up to nine pieces. Delivery is six weeks ARO.
For additional information, contact Aries Electronics, Inc., P.O. Box 130, Frenchtown, NJ 08825.
Tel: 908/996-6841; Fax: 908/996-3891; E-mail: info@arieselec.com; Web: http://www.arieselec.com,
Data sheet #24012�www.arieselec.com/products/24012.pdf.
READER SERVICE INQUIRIES: Please forward all reader service inquiries to Frank Folmsbee, Aries Electronics, Inc., P.O. Box 130, Frenchtown, NJ 08825.
EDITORS NOTE: Headquartered in Frenchtown, NJ, Aries Electronics, Inc., manufactures an extremely broad range of custom and standard interconnection and packaging products for electronics. Industry leading products include Zero Insertion Force (ZIF) test sockets for DIP, PGA, PLCC and SOIC devices; the Correct-A-Chip� product line of "intelligent connectors"; adapters and connectors; several patented concepts for BGA (ball grid array) and LGA (land grid array) sockets; and an extensive array of high frequency test and burn in sockets. The company also specializes in meeting custom requirements for its customers.
Nov 10, 2004 -
NEW ARIES SHORTFORM CATALOG COVERS PIN BALL BGA
Jul 08, 2003 -
Aries' New Cost-Effective CSP/MicroBGA Test and Burn-In Socket
Jun 16, 2003 -
Aries Dramatically Reduces Lead Times for RF Test Socket Price Quotes Through New Insta-Quote System
Dec 18, 2001 -
NEW 1.00 mm AND 1.27 mm PITCH BGA SOCKETS AND ADAPTERS NOW AVAILABLE FROM ARIES
Nov 14, 2001 -
Aries Introduces RF Test Sockets
Jun 28, 2024 -
Jun 26, 2024 -
Jun 25, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
NEW RF CENTER PROBE TEST SOCKET FOR DEVICES news release has been viewed 1093 times
