  • Seika Machinery Introduces Updates to Popular Malcom and Unitech Process Control Systems
Aug 09, 2018
SPS Series Paste Mixers
Seika Machinery, Inc., a leading provider of advanced machinery, materials and engineering services, is pleased to announce that it carries six new process control devices from MALCOM and UNITECH. These include: SPS series paste mixers, viscometers, wetting balance testers, profilers / camera systems, reflow simulators and PCB board cleaners.
  • From refrigerator to screen printer in less than 15 minutes.
  • Automated operation for gentle softening, and even consistency.
  • Uses airtight containers to prevent oxidation and humidity.
  • Models are available for single or dual solder paste jars (up to 1kg each).
Viscometers
  • Help eliminate misprints due to incorrect paste conditions.
  • Patented spiral-pump sensor provides dynamic, quick, easy, repeatable measurements.
  • Satisfies international standards for paste viscosity measurement.
  • Data logging of viscosity and temperature data.
  • Models include hand-held, table-top, laboratory, and extra-small sample size versions.
Wetting Balance Testers
  • Evaluate the wetting profiles of through-hole and SMT components, leads, solder and flux.
  • Simulate the temperature profiles of wave soldering machines or SMT reflow ovens.
  • Conforms to international standards for wetting balance testing.
  • Log and compare the test results for easy analysis.
Reflow Oven Temperature, Oxygen Concentration, Convection Air Velocity Profilers / Camera System
  • Complete profiling of reflow oven, including oven temperature, O2 concentration, and convection air velocity.
  • Verifies that ovens are performing at optimal conditions and troubleshoots problem areas.
  • 6 and 12 channels reflow oven thermo-profiling.
  • O2 concentration profile data for the entire Nitrogen oven.
  • Convection air velocity profile data for the entire oven.
  • Record video of a PCB as it travels through the oven with the ability to focus on specific areas of concern to isolate problems.
  • Display the profile data along with the O2 concentration, air velocity, or camera image.
Reflow Simulators
  • True representation of a multi-zone reflow oven in a table-top form factor.
  • Top & bottom side heaters in conjunction with hot air convection.
  • Viewing windows allow you to monitor the process during reflow, and with the optional VDM-3 camera system, record video while overlaying time and temperature profile data.
  • The RDT-250C will allow for 330mm x 250mm PCB boards, where the SRS-1C allows for a 70mm x 70mm sample board or test piece.
  • Reflow simulators can be run using an air or Nitrogen environment.
UNITECH PCB BOARD CLEANER (UC-250M-CV)
  • Three-stage PCB board cleaning system is the most effective way to remove dust and debris from the PCB surface.
  • The first stage is a brush and vacuum.
  • The second stage uses a dual rubber sticky roller system.
  • The third stage uses an ionized air blower for anti-static board preparation.
  • Select any combination of the cleaning stages to fit your needs.
  • PCB sizes are as follows:
    • Width: 50~250mm
    • Length: 100~330mm
    • Thickness: 0.5~2.0mm
  • Larger and custom sizes are available.
Seika Machinery Introduces Sayaka SAM-CT3SLA Semi-Automatic Desktop Dry Slicer
Jul 22, 2024 -
Jul 22, 2024 -
May 06, 2024 -
Seika Machinery Releases McDry Introduction Video Showcasing Innovative Dry Cabinets
May 06, 2024 -
Seika Machinery Holds 30th Anniversary Celebration at 2024 IPC APEX EXPO
Apr 29, 2024 -
Seika Machinery to Sponsor and Present at the High Reliability Technology Advancement Research Forum
Apr 15, 2024 -
Seika Machinery Recognizes Outstanding Sales Achievements at 2024 IPC APEX EXPO
Mar 18, 2024 -
Seika Machinery to Present Solutions to Optimize Production Processes at APEX 2024
Jan 08, 2024 -
Seika Machinery Celebrates Three Decades of Excellence in Supplying Electronics Machinery & Products
Dec 25, 2023 -
Seika Machinery Rolls Out Fully Automatic Sawa Ecobrid Stencil Cleaner and Sayaka CT23S Tabletop Router
288 more news from Seika Machinery, Inc. »
Aug 14, 2024 -
Aug 14, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Seika Machinery Introduces Updates to Popular Malcom and Unitech Process Control Systems news release has been viewed 1545 times
