  • Nordson ASYMTEK's Select Coat SC-280 Film Coater Improves Material Utilization by 30 to 50 Percent in Conformal Coating Applications
May 06, 2011
Nordson ASYMTEK, a leader in dispensing, coating, and jetting technologies, introduces its new film coater for automated, selective, and precision application of conformal coating materials. The Nordson ASYMTEK Select Coat® SC-280 provides greater than 99 percent fluid transfer efficiency, improving material utilization by 30 to 50 percent. It selectively coats complex circuit boards in seconds. Because the coating material is not atomized and is precisely applied to the selected areas, overspray, masking, and rework associated with conventional conformal coating processes are minimized or eliminated.
"Nordson invented film coating over 20 years ago and is continuing to make evolutionary improvements to this process using our years of experience and customer feedback," said Hector Pulido, conformal coating product specialist, Nordson ASYMTEK. "Nordson ASYMTEK's SC-280 design is based on the popular Nordson SC-104/204 film coater, which has been an industry standard for many years. The new coater has an even faster response, is more repeatable, and the solenoid has a longer life. It's easy to clean and is environmentally friendly. The system improves material utilization, achieves less waste, and reduces costs."
The film coater applies conformal coating material in a controlled, uniform film rather than an atomized spray. Material is directed under low pressure through the dispenser and dispensing nozzle. Material is applied to the circuit board prior to the point of atomization.
The SC-280 has a single valve design and comes in two versions, circulating (SC-280C) and non-circulating (SC-280N). It handles viscosities of less than 100 centipoise (cps). Coating thicknesses range from 0.5 to 8 mils for solvent-based materials. The stainless steel fluid path is compatible with virtually all coating materials. A variety of cross-cut nozzles are available to dispense film pattern widths from 6 to 19 mm (~0.25 to 0.75 inch). Each nozzle delivers excellent edge definition with a tolerance of ± 0.75 mm (~0.030 inch). The film coater has a zero to 90 degree rotating axis. An optional five-axis accessory allows tilting of the nozzle to coat all four sides and under the components. Non-atomized coating process and ventilated system reduce volatile organic compound (VOC) emissions.
Nordson ASYMTEK, a world leader in precision automated fluid dispensing, conformal coating, and jetting technologies, designs and manufactures a full line of dispensing and coating systems, supported by a global applications and service network. Recognized for its innovative equipment and excellent service, Nordson ASYMTEK continues to offer advanced dispensing solutions for a range of precision assembly processes. These include semiconductor packaging, printed circuit boards, LEDs, flat panel displays, medical and biotechnical devices, and solar and photovoltaic products. Nordson ASYMTEK is an ISO 9001:2008 certified company and has received numerous awards for its service excellence and product innovations.
Nordson Corporation (Nasdaq: NDSN) is one of the world's leading producers of precision dispensing equipment that applies adhesives, sealants, liquid and powder coatings and other materials to a broad range of consumer and industrial products. The company also manufactures equipment used in the testing and inspection of electronic components as well as technology-based systems for UV curing and surface treatment processes. Headquartered in Westlake, Ohio, Nordson has direct operations and sales support offices in more than 30 countries.
Nordson Electronics Solutions completes its Europe location move to a new, state-of-the-art facility
May 17, 2024 -
Nordson Electronics Solutions releases the new ASYMTEK Select Coat® SL-1040 Conformal Coating System - a new standard in conformal coating excellence and reliability
Aug 14, 2023 -
Nordson's semiconductor advanced packaging solutions will be demonstrated at SEMICON Taiwan 2023
Aug 26, 2022 -
Nordson Electronics Solutions announces distributor SmartTec Nordic A/S to support ASYMTEK Products in Denmark and Norway
Sep 26, 2021 -
Jun 30, 2021 -
Jun 23, 2021 -
Apr 29, 2021 -
Boost Fluid Dispensing Throughput up to 100% with the New ASYMTEK Forte™ MAX System from Nordson Electronics Solutions
Oct 29, 2020 -
Oct 12, 2020 -
75 more news from ASYMTEK Products | Nordson Electronics Solutions »
Jan 06, 2025 -
Europlacer and Scheiber Enhance Partnership with Integration of ii-N2 Placement Machine
Jan 06, 2025 -
The Test Connection, Inc. Celebrates 45 Years of Excellence in Test Engineering Solutions
Jan 06, 2025 -
JAVAD EMS Marks 15 Years of Innovation and Growth in High-Reliability Manufacturing
Jan 06, 2025 -
BTU International Celebrates 75 Years of Innovation in Thermal Processing Technology
Jan 06, 2025 -
Selectronic Assembly Recognizes 5th Anniversary with Strong Industry Presence and Continued Growth
Jan 06, 2025 -
Amtech Marks 30 Years: Celebrating "The Amtech Difference" in Manufacturing
Jan 06, 2025 -
IPC Expands Presence in Malaysia, Hires New Country Manager
Jan 06, 2025 -
NEOTech Commemorates a Decade of Growth and Strong Partnerships, Driving Innovation in Electronics Manufacturing
Jan 06, 2025 -
Sono-Tek Celebrates 50 Years of Innovation in Ultrasonic Spray Coating Technology
Jan 06, 2025 -
MicroCare Welcomes Greg Gascon as Strategic Account Executive
Manufacturing Software
