  • ProDEK Closed Loop Printing Technology Raises the Bar on Dynamic Process Control
Feb 15, 2012
In a significant technology breakthrough set to upend former industry perceptions of closed loop printing processes, DEK announces the development and commercial launch of its revolutionary new closed loop innovation, ProDEK
Making its global market debut during the APEX event from February 28 through March 1 in San Diego, California, ProDEK introduces new levels of dynamic print process control, enabling real-time continuous alignment adjustments and cleaning frequency adaptation to dramatically enhance throughput, improve yield and limit operator intervention.
To put it simply, ProDEK makes your printer smarter and more intuitive,” explains Brian Smith, DEK Americas General Manager for Electronics Assembly.  “Built on unique print software capability, ProDEK works in tandem with solder paste inspection (SPI) data and uses a high level of process reference to accurately control print alignment and cleaning functionality.  This is the most robust and repeatable ‘hands-off’ print technology available.”
From paste offset (alignment) data feeds delivered to the printer by the SPI system, ProDEK monitors a configurable quantity of printed circuit boards (PCBs), sending an independently corrected forward and reverse offset to the printer, which then adjusts paste on pad alignment in real-time.  Utilizing barcode tracking technology, ProDEK guarantees printed and inspected board synchronization.
In addition to real-time, continuous alignment adjustments which add zero throughput overhead to the print/inspection process, ProDEK also monitors high area warning counts from the SPI data feeds, which may be an indicator of excessive or insufficient understencil cleaning.   The novel technology can automatically adapt the cleaning frequency to suit current process conditions, optimizing the understencil cleaning process and thereby introducing more stability while significantly reducing consumables usage. Available on all new DEK print platforms and retrofittable on installed DEK systems, ProDEK is currently compatible with market-leading SPI technology from CyberOptics, Koh Young and Parmi.
ProDEK has been proven to proactively prevent defects, optimize print performance and ensure the highest possible first-pass yield.  When field tested at several leading electronics assembly firms, ProDEK results revealed that the offset correction functionality alone reduced defects by nearly 50% on average.
As Smith concludes, “The true value of ProDEK is the process expertise and decision- making capability that’s built into the software: it’s an automated knowledge base that delivers unprecedented levels of control.”
To see ProDEK in action alongside Koh Young’s aSPIre 2 SPI system during APEX 2012, visit DEK at booth #2600.
DEK is a global provider of advanced materials deposition technologies and support solutions including printing equipment platforms, stencils, precision screens and mass imaging processes used across a wide range of applications in electronics pre-placement subassembly, semiconductor wafer manufacture, and alternative energy component production. For more information, visit DEK at www.dek.com.
Oct 05, 2017 -
Smart Factory Check: how smart is your electronics production today?
Oct 05, 2017 -
Sep 06, 2017 -
Don't miss! ASM @ SMTAi 2017
Feb 28, 2014 -
Experience Unmatched Printing Knowledge and Future Technology Capability with DEK at APEX 2014
Mar 21, 2012 -
DEK Earns its Tenth Consecutive Service Excellence Award; Customers Consistently Impressed with Support
Feb 15, 2012 -
Jan 20, 2012 -
DEK signs contract with Ortana at Productronica 2011
Dec 21, 2011 -
Indium Corporation snaps up DEK Horizon 01iX at Productronica 2011
Dec 02, 2011 -
DEK and Interlatin Take Productivity on Tour to Overwhelming Response
Aug 03, 2011 -
Great Lakes Engineering Licenses DEK VectorGuard® Technology
134 more news from ASM Assembly Systems (DEK) »
Sep 13, 2024 -
RELIANCE 57C405-E
Sep 13, 2024 -
HMS ABC-PDP AB7000-B
Sep 13, 2024 -
Sep 13, 2024 -
Sep 13, 2024 -
YOKOGAWA S9400UK
Sep 13, 2024 -
Sep 13, 2024 -
Sep 13, 2024 -
ABB DTDX707A 61430001-WG
Sep 13, 2024 -
GE IC220STR001
Sep 13, 2024 -
ProDEK Closed Loop Printing Technology Raises the Bar on Dynamic Process Control news release has been viewed 1102 times
Manufacturing Software
