  • DEK’s DirEKt Ball Placement Technology Advances toward Microsphere Capability
Aug 19, 2009
Extending its capabilities for placing solder spheres at high speed, DEK’s proven DirEKt Ball Placement™ process now enables accurate solder sphere deposition for spheres as small as 200µm in diameter with pitches as tight as 300µm. With the ability to achieve this accuracy and precision at a first pass yield of over 99.99%, DirEKt Ball Placement delivers the speeds necessary for modern package manufacture without sacrificing anything in the way of performance.
Unlike alternative methods that employ serial approaches for placement of solder balls, the parallel print process of DirEKt Ball Placement allows for unmatched, repeatable accuracy and exceptionally fast cycle times which are completely independent of I/O count. While these statistics are arguably impressive and consistent with requirements for next-generation wafer-level CSP devices, DEK is also upholding its pledge to continuously enhance DirEKt Ball Placement capability.
As part of this commitment, the mass imaging leader has designed the Galaxy Thin Wafer System, a high-accuracy print platform capable of meeting the demands of thinned wafer processes and precision microsphere ball placement. The system’s newly engineered wafer pallet, which is flat to less than 10µm with the ability to accommodate wafers as large as 300mm and as thin as 75µm, is the foundation for advancing sphere placement processes to the next-generation.
“While we have achieved 99.99% repeatable first pass yield with 200µm balls at 300µm pitch in high-volume production, even more highly miniaturized spheres have been successfully placed in a lab environment, with work ongoing to prove the process in the field,” says DEK’s Semicon and Alternative Applications Manager, David Foggie. “Our active development program to deliver sub-100µm microsphere placement is well underway, with early results delivering an exceptionally high first-pass yield”
The DirEKt Ball Placement system utilizes two side-by-side print platforms, with the first system using flux imaging technology to precisely deposit flux at each interconnect site. The second printer, a Galaxy Thin Wafer System equipped with an advanced enclosed sphere transfer head capable of holding up to 100 million solder balls, then accurately seats each ball into the flux. Enabled by the enhanced stability and security of the Galaxy Thin Wafer System, DEK’s DirEKt Ball Placement technology can process as many as 45 wafers per hour.
“High UPH microsphere placement is clearly the cost-effective way forward for wafer-level CSP manufacture,” concludes Foggie. “DEK’s DirEKt Ball Placement system delivers the precision, repeatability, platform flexibility and low cost of ownership commitment necessary for advancement of this critical packaging technology.”
About DEK
DEK is a global provider of advanced materials deposition technologies and support solutions including printing equipment platforms, stencils, precision screens and mass imaging processes used across a wide range of applications in electronics pre-placement subassembly, semiconductor wafer manufacture, and alternative energy component production. For more information, visit DEK at http://www.dek.com.
Oct 05, 2017 -
Smart Factory Check: how smart is your electronics production today?
Oct 05, 2017 -
Sep 06, 2017 -
Don't miss! ASM @ SMTAi 2017
Feb 28, 2014 -
Experience Unmatched Printing Knowledge and Future Technology Capability with DEK at APEX 2014
Mar 21, 2012 -
DEK Earns its Tenth Consecutive Service Excellence Award; Customers Consistently Impressed with Support
Feb 15, 2012 -
ProDEK Closed Loop Printing Technology Raises the Bar on Dynamic Process Control
Feb 15, 2012 -
Jan 20, 2012 -
DEK signs contract with Ortana at Productronica 2011
Dec 21, 2011 -
Indium Corporation snaps up DEK Horizon 01iX at Productronica 2011
Dec 02, 2011 -
DEK and Interlatin Take Productivity on Tour to Overwhelming Response
134 more news from ASM Assembly Systems (DEK) »
Sep 07, 2024 -
FOXBORO FBM207B Channell Solated P0914WH
Sep 07, 2024 -
FOXBORO FBM228 P0922QS COMMUNICATION FIELDBUS MODULE
Sep 07, 2024 -
FOXBORO P0931RQ Cable
Sep 07, 2024 -
FOXBORO FBM215 CHANNEL ISOLATED 8 COMMUNICATION HART OUTPUT
Sep 07, 2024 -
FOXBORO CP40 Model
Sep 07, 2024 -
FOXBORO FBM230 P0926GU
Sep 07, 2024 -
FOXBORO P0916VC
Sep 07, 2024 -
FOXBORO AD916AG
Sep 07, 2024 -
FOXBORO P0904BS P0904BS-0E
Sep 07, 2024 -
FOXBORO PO177VS
DEK’s DirEKt Ball Placement Technology Advances toward Microsphere Capability news release has been viewed 1060 times
