  • Heraeus Electronics Brings Fully Matched Power Module Systems and DTS® Innovation to APEC 2026
Mar 02, 2026
Heraeus Electronics will exhibit in Booth 1438 at APEC 2026 (IEEE Applied Power Electronics Conference and Exposition) at the Henry B. Gonzalez Convention Center in San Antonio, Texas. The company will showcase its power module portfolio of matched materials, highlighting how coordinated material choices across die attach, interconnection, and substrates can improve performance, reliability, and manufacturability.
At the center of the exhibit will be the Heraeus Electronics Die Top System (DTS®), including DTS® Gold and DTS® Silver. DTS® replaces conventional solder die attach and aluminum wire bonding with a fully sintered interconnection approach, delivering more than 50% higher die current capability and up to 50 times longer lifetime, while enabling junction temperatures above 200°C. These gains allow designers to reduce power derating and optimize module layouts without adding process complexity.
DTS® Gold is designed for applications requiring the highest electrical and mechanical performance, while DTS® Silver provides a cost-efficient alternative with a strong cost-per-ampere advantage. Both variants support one-step sintering of chip front and backside, use standard sintering and die-bonding equipment, and can be adapted to common chip designs.
In addition to DTS®, Heraeus Electronics will present complementary materials engineered to work together as part of an integrated power module system:
  • PowerCu Soft wires and ribbons – Soft copper interconnect materials matched to DTS® properties, providing a wide bonding window and reliable electrical and thermal performance.
  • mAgic® PE338 die-attach – A pressure sinter paste optimized for high-reliability die attach and offering stable thermal paths
  • mAgic® PE360 sintering materials – Large-area silver sintering solutions for module attach that deliver uniform bond lines and strong thermal and mechanical stability at relatively low pressure and temperature.
  • Microbond® solder preforms – Innolot®-based preforms designed for module-to-heatsink attachment, offering a balance of durability, processing simplicity, and material cost control.
  • Condura®.ultra metal-ceramic substrates – Advanced silver-free AMB substrates combining high thermal conductivity with mechanical stability, supporting demanding power density and reliability requirements.
Heraeus Electronics will also highlight its engineering and application services, available through its global Technology and Application Centers. These services support customers with prototype builds, material matching, and reliability testing to help accelerate development, validate designs, and transition concepts into production.
Visitors to Booth 1438 can learn how Heraeus Electronics’ matched material systems enable more predictable performance, faster development cycles, and scalable manufacturing for next-generation power electronics.
For more information about Heraeus Electronics and its power module solutions, visit www.heraeus-electronics.com.
Feb 23, 2026 -
Heraeus Electronics to Highlight Module Attach Material Options at APEX 2026
Feb 09, 2026 -
Heraeus Electronics to Share Cutting-Edge Packaging Insights in Three Presentations at CIPS 2026
Nov 24, 2025 -
Heraeus Electronics Wins 2025 Global Technology Award for Its Module Attach Sinter Paste mAgic® PE360
Sep 24, 2025 -
Heraeus Electronics to Showcase Advanced Packaging Materials at SMTA International 2025
Sep 08, 2025 -
Heraeus Electronics to Introduce Breakthrough Vertical Wire Bonding Innovation at SEMICON West 2025
Aug 11, 2025 -
Heraeus Materials Singapore Celebrates 40 Years of Innovation and Partnership
May 12, 2025 -
Heraeus Electronics Showcases Sustainable Semiconductor Materials at SEMICON Southeast Asia 2025
Apr 14, 2025 -
Heraeus Electronics to Debut New Die Top System Material with Insightful Live Presentations at PCIM Europe 2025
Feb 24, 2025 -
Heraeus Electronics, MacDermid Alpha Electronics Solutions and Henkel Win Patent Dispute Against Senju Group
Feb 24, 2025 -
Heraeus Electronics showcases innovative solutions in soldering and sintering at APEX 2025
35 more news from Heraeus »
Apr 06, 2026 -
Apr 06, 2026 -
Apr 06, 2026 -
Apr 06, 2026 -
Apr 06, 2026 -
Apr 06, 2026 -
Apr 06, 2026 -
Apr 06, 2026 -
Apr 06, 2026 -
Apr 06, 2026 -
