New LPKF ProtoMat D104 with UV Laser Tool
Nov 21, 2013
The ProtoMat D104 was developed for use in highly demanding laboratory and development facilities.
LPKF Laser & Electronics AG presents a spectacular new development: The LPKF ProtoMat D104 unites the best features of advanced LPKF ProtoMats with the high precision of the ProtoLaser systems. The highlight of this product innovation is a special UV laser.
Circuit board plotters in the LPKF ProtoMat range previously cut out circuit structures from completely coated base materials using negative milling. The ProtoMats mill insulation channels into the conductive layer, leaving the areas that will later be the conductive traces. Tool changing allows contours to be milled or vias to be drilled in circuit boards. LPKF ProtoLasers, on the other hand, are particularly useful when extremely fine structures are required.
The new LPKF ProtoMat D104 now extends the options of the ProtoMats to include machining of especially delicate materials. Thanks to the integrated UV laser-tool, the D104 enables structures down to the ultrafine conductor range to be produced. Depending on the material, structures with a pitch of 200 µm (100 µm minimum track width, 100 µm minimum space) can be applied by milling; with the laser tool, the achievable pitch is reduced to 80 µm (50 µm minimum track width, 30 µm minimum space). Even ceramics can be structured using the laser tool. The ProtoMat D104 is recommended for PCB prototyping, among other things, because of its extremely high precision, short machining times, high-speed milling/drilling at 100,000 RPM, 15 tool change options (automated) plus UV laser tool, non-contact tool depth setting and working depth limitation, a vision system with a measuring camera, and a maintenance-friendly housing.
The ProtoMat D104 was developed for use in highly demanding laboratory and development facilities. After internal introduction of the beta version at a distributors’ meeting, LPKF Laser & Electronics AG will present its innovation on November 12–15, 2013 at productronica in Munich (Hall B2, Booth 105). The LPKF ProtoMat D104 is expected to be ready for shipment in early 2014.
LPKF Laser & Electronics AG manufactures machines and laser systems used in electronics fabrication, medical technology, the automotive sector, and the production of solar cells. Around 20 percent of the workforce is engaged in research and development.
Jan 29, 2014 -
LPKF Expands Management Team
Jan 16, 2014 -
Rapid Prototyping of Printed Circuit Boards at AFCEA West
Nov 21, 2013 -
Step-Up Stencils with the StencilLaser
Nov 15, 2013 -
LPKF raises guidance slightly for 2013
Sep 10, 2013 -
Wave of innovation at productronica fair - LPKF presents four new systems in Hall B2, Booth 105
Aug 27, 2013 -
In-House PCB Prototyping Comes to Eptech Mississauga and Ottawa
Jan 18, 2013 -
PCB Processing Solutions a Highlight of IPC/APEX Expo 2013
Dec 03, 2012 -
New Webinar Explores SMT Stencil Aperture Size and its Relationship with Solder Paste Volume
Sep 12, 2012 -
LPKF to Showcase UV Depaneling System at SMTA International
Aug 23, 2012 -
LPKF to Showcase Top-of-the-Line PCB Milling Machine at PCB West 2012
22 more news from LPKF Laser & Electronics »
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
New LPKF ProtoMat D104 with UV Laser Tool news release has been viewed 1857 times
