  • Parvus Combines Low-Power 5x86 AMD� CPU with Dual 10/100 Ethernet Controllers and Quad Serial Ports in SpacePC� 4200 PC/104-Plus Single Board Computer
Nov 20, 2003
SpacePC 4200 5x86 133HMz PC/104-Plus CPU
SALT LAKE CITY, UTAH - November 20, 2003 - Parvus� Corporation today unveiled its SpacePC� 4200 CPU, a fanless 5x86 class PC/104-Plus processor board based around the 32-bit AMD� �lan� SC520 microcontroller. The product is priced at $314/each in volume orders of 100+ units.
Operating at clock speeds of 133MHz with a typical power consumption of only 4.6W, the 4200 Series module integrates two (2) 10/100MBps Fast Ethernet controllers and four (4) serial ports (2 RS-232, 2 RS-232/422/485) to provide embedded systems in aerospace, industrial, medical, and transportation applications with a rich network and communication feature set. Other standard onboard peripherals include a bi-directional EPP/ECP parallel port, EIDE hard drive interface, speaker port, AT keyboard and PS/2 mouse interfaces, real-time clock, watchdog timer, and two additional 16-bit counter/timers.
To enhance reliability, the module does not require any active cooling, has no moving parts and comes equipped with 64MB of soldered SDRAM memory. Available in both standard (0�C to +60�C) and extended (-40�C to +85�C) temperature rated versions, the 4200 Series incorporates an IDE controller that supports the use of rugged Solid State Disk (SSD) devices, such as DiskOnModule�, CompactFlash�, and ATA Flash drives to securely store user data in harsh environmental conditions were standard devices do not reliably operate.
This space-saving (3.550� x 3.775�) PC/104-Plus CPU module also includes drivers for both Windows� and Real-Time Operating Systems (RTOS), such as Linux�, QNX� and VxWorks�. It integrates both the PC/104 (ISA) and PC/104-Plus (PCI) buses, enabling the 4200 Series to be easily stacked on top of other PC/104 add-on modules (i.e. video accelerators, frame grabbers, and digital I/O boards). Its BIOS is stored in a 1MB EPROM, which comes pre-loaded with a ROM-DOS� kernel to facilitate rapid implementation.
While supplies last, a limited quantity of the SpacePC 4200 CPU is available for free evaluation. Visit http://www.SpacePC.com for more information about the whole line of SpacePC products or call 800-483-3152 to place an order.
ABOUT PARVUS
Parvus Corporation is a leading North American manufacturer and systems integrator of modular computer boards, enclosures, displays and embedded systems based on the PC/104 circuit board standard. Parvus offers rugged, commercial-off-the-shelf (COTS) computing solutions ideal for avionics, military, medical, industrial, and transportation OEMs. For more information, visit http://www.parvus.com or call 801.483.1533.
NOTE FOR EDITORS
See http://www.parvus.com/news.htm for high-resolution, downloadable artwork related to this announcement.
Jan 29, 2008 -
Parvus Mobile 802.11 Hotspot Enables Wi-Fi Trial for MBTA Passengers, First U.S. Wireless Internet Service for Commuter Rail
Jan 07, 2008 -
Parvus Selects DDC�s New MIL-STD-1553 PC/104-Plus Card for US Navy Aircraft Upgrade Program
Nov 03, 2005 -
Parvus Releases Statement on RoHS Compliance
Sep 12, 2005 -
COM-1440 PC/104-Plus 4-Port USB 2.0 Controller from Parvus Now Available with Support for uDiskonChip SSD
Aug 24, 2005 -
Parvus Announces Availability of OrbiTrak� GSM, a PC/104 Tri-Band GSM Cellular Modem Solution with 12-Channel GPS Receiver
Jul 20, 2005 -
Parvus Sponsors Students in National Autonomous Underwater Vehicle Event
Jul 20, 2005 -
Jul 11, 2005 -
Parvus Unveils Three Fanless 800MHz Pentium III PC/104-Plus CPU Modules Designed for -40C to +85C Extended Temperature
Jun 16, 2005 -
Parvus� Parent Company, Eurotech, Announces Plans for Public Offering on Italian Stock Exchange
Jun 08, 2005 -
Parvus to Unveil Military-Grade, Galvanically Isolated Power Supply for Embedded Computer Systems
39 more news from Parvus Corporation »
Sep 18, 2024 -
ABB NTCS04 infi90 CONTROLS MODULE TERMINATION UNIT
Sep 18, 2024 -
ABB SPCIS22 l/O Control Module
Sep 18, 2024 -
ABB SPDSM04 Module installation unit
Sep 18, 2024 -
ABB NTRO12-A Analog input Terminal
Sep 18, 2024 -
ABB SPDSO14 Digital output Module
Sep 18, 2024 -
ABB NTDI21-A Inverter Circuit Board PCB
Sep 18, 2024 -
ABB SPDSI22 Digital input Module
Sep 18, 2024 -
ABB SPDSI14 Analog input module
Sep 18, 2024 -
ABB NKAS01-15 infi 90 Termination Cable
Sep 18, 2024 -
ABB NTAI06 terminal board
Parvus Combines Low-Power 5x86 AMD� CPU with Dual 10/100 Ethernet Controllers and Quad Serial Ports in SpacePC� 4200 PC/104-Plus Single Board Computer news release has been viewed 837 times
Void Free Reflow Soldering
