  • COM-1440 PC/104-Plus 4-Port USB 2.0 Controller from Parvus Now Available with Support for uDiskonChip SSD
Sep 12, 2005
COM-1440 from Parvus
SALT LAKE CITY, UTAH � September 12, 2005 � Parvus Corporation today announced the availability of the new COM-1440, a PC/104-Plus form factor 4-port high-speed USB 2.0 host controller board capable of directly powering attached USB devices. The COM-1440 now also comes with onboard mounting support for two M-Systems� uDiskonChip� (uDOC) Solid State Disks (SSD).
Delivering USB data transfer speeds of up to 480 Mbps, the COM-1440 features four downstream USB ports, along with two onboard SSD mezzanine sockets for up to 4GB of secure high-speed Flash memory. Notably, two of the product�s USB ports are enhanced to supply 2 Amps of drive for directly powering attached USB mass storage and other devices through the USB cable.
The new uDOC compatible sockets enable rugged high-performance, solid state storage with high throughput rates (20MB/sec read and 10MB/sec write) using USB 2.0, a modern design approach for advanced embedded systems. The two memory device sockets are connected in parallel with two of the external USB ports. When the two uDOC sockets are populated, one standard (500mA) USB port and one enhanced drive USB port are free for system expansion. Accessible as independent logical disks and available in extended temperature formats, uDOC encrypted solid state flash disk devices from M-Systems are available in capacities ranging from 64 to 2048MB each.
PRICING AND AVAILABILITY
This product is currently in stock and priced at $132/each in 100-unit quantities.
SPECIFICATIONS
� USB Ports: Four independent USB 2.0 downstream ports
� Current Drive: 2 standard 500mA drive USB ports, 2 enhanced ports with 2000mA drive capability
� USB Compliance: OHCI 1.0a and EHCI USB 0.95; Reverse Compatible with USB 1.1
� Operating Temperature: -40�C to +85�C
� Bus Architecture: PCI bus compliance with PCI Rev 2.2, 32-bit bus
� Transfer Speed Modes: high speed (480 Mb/s), full-speed (12 Mb/s) and low-speed (1.5 Mb/s).
� Physical Dimensions: 3.550" x 3.775" (PC/104-Plus)
� SSD Support: Two compatible sockets for secure high-speed Flash memory disks (up to 4,096MB total capacity); M-Systems uDOC disks sold separately
� OS Compatibility: Windows XP Embedded, CE, Linux, QNX, VxWorks, and other RTOSs
ABOUT PARVUS
Since 1983, Parvus Corporation has been a strategic systems engineering and development partner for aerospace, defense, transportation, and industrial OEMs. Specializing in the rapid design and production of turnkey embedded computing solutions for harsh environments, Parvus leverages extensive expertise in systems integration and a complete line of rugged PC/104, PC/104-Plus, and PCI-104 computer modules to ensure high reliability and accelerate time-to-market for its customers. Parvus is the US arm of the Eurotech Group, which has operations across Europe, North America and Asia.
Visit http://www.parvus.com or call 801.483.1533 for more information.
NOTE FOR EDITORS
A high-resolution photo of these products can be downloaded at http://www.parvus.com/News/MediaDownloads/
Jan 29, 2008 -
Parvus Mobile 802.11 Hotspot Enables Wi-Fi Trial for MBTA Passengers, First U.S. Wireless Internet Service for Commuter Rail
Jan 07, 2008 -
Parvus Selects DDC�s New MIL-STD-1553 PC/104-Plus Card for US Navy Aircraft Upgrade Program
Nov 03, 2005 -
Parvus Releases Statement on RoHS Compliance
Aug 24, 2005 -
Parvus Announces Availability of OrbiTrak� GSM, a PC/104 Tri-Band GSM Cellular Modem Solution with 12-Channel GPS Receiver
Jul 20, 2005 -
Parvus Sponsors Students in National Autonomous Underwater Vehicle Event
Jul 20, 2005 -
Jul 11, 2005 -
Parvus Unveils Three Fanless 800MHz Pentium III PC/104-Plus CPU Modules Designed for -40C to +85C Extended Temperature
Jun 16, 2005 -
Parvus� Parent Company, Eurotech, Announces Plans for Public Offering on Italian Stock Exchange
Jun 08, 2005 -
Parvus to Unveil Military-Grade, Galvanically Isolated Power Supply for Embedded Computer Systems
Jun 03, 2005 -
Parvus Joins American Public Transportation Association; Parvus to Exhibit at International Public Transportation Expo 2005 in Dallas
39 more news from Parvus Corporation »
Aug 09, 2024 -
COM-1440 PC/104-Plus 4-Port USB 2.0 Controller from Parvus Now Available with Support for uDiskonChip SSD news release has been viewed 1085 times
